Old 10-11-2008, 10:45 AM
MBP1214 MBP1214 is offline
Power Window
How do I remove the passanger side door panel so I can replace the window regulator?
Old 10-11-2008, 10:58 AM
Re: Power Window
Removing the door panel is easy. There are only 5 screws to remove.
Open the door and take out the 2 screws on the front edge of the door panel, near the door hinge.
There is another screw located under the door handle, hidden behind the plastic plate which justs pops out with a small-bladed screwdriver (preferably magnetic)
There are also 2 more screws hidden under the felt mat inside the door armrest. Just peel it away to expose the screws, These are the most important ones as they hold the entire armrest to the door frame. You cannot remove the panel with these screws in place.
Once all screws are removed, just pop the clips around the bottom of the door panel by pulling gently. Once free, lift the entire panel up slightly and pull away from the door frame to see the wiring. There are 2 electrical connectors that must be disconnected; one is for the power window switch cluster and one is for the door courtesy light.
Replacement is the reverse order. The only possible minor hassle is lining up the door lock button to slide into the door panel opening, but usually it is not a problem. Everything will line back up perfectly.
For photos on how to replace the sleeve lock regulator (which is usually the only part that goes bad) CLICK HERE
Subaru part number 62101PA081 is the sleeve lock regulator. It is a redesign of the clip and is found starting with the 94 SVXs. It will clip onto the place where the 92-93 window clip used to be.
Evidently there was a problem with this clip and so Subaru decided to offer this as a replaceable part starting in '94.
Cost of the part is $7.58 from subaruparts.com and about $10.00 from your dealer.
