Blinking CEL... I'm Dumb Founded...
Tonight my friend showed up at the local Euro GTG with her 96 Ebony. Apparently she had a couple seals re-done and vacumm lines replaced. But now shes throwing codes. Apparently the o2 sensors and EGR code. Now, the other issue is, dis-connecting the battery doesn't doesn't clear the codes. So now I'm dumdfounded and don't know. I was going to try putting my stock MAF in and see if that helps the low idle. But as for the O2 sensors and BLINKING CEL I'm lost.
Thanks in advance guys.
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs! Sand Diego SCCA Solo 2 #308 RIP 84 VW Scirocco 02 WRX 88 XT6(regret the day I left her behind) socaleuro.com They like the flat 6... Check My New Homepage.. |
go to autozone....they have the OBDII tool and can clear the codes with it if you ask. It's a free service provided by all autozone's...Be courteous though.
Insert Witty Quip Here... No more subie Current Cars: 96 Chevy Caprice Impala SS clone 93 Chevy Full-size blazer Soon: 2002 Honda CBR 954RR |
Since its not my car I don't know how much truth is in what she told me or what she was told by the mechanic.
I worked there for 2 1/2 years... It'll pull the codes and say what they are...If for some reason it doesnt say what they are, the autozone employee should have been smart enough to write them down in a slip of paper and cross reference them in the computer thats in the store and it should have said what it is.
Also, there's a n33t little button on the obdII tool that says 'erase' , this will erase any codes stored, but if its a problem that the computer detects immediately, it will come back on after starting the vehicle.
I'll have to talk to her and work something out. Just frustating I keep telling her to join the network and come to me with any questions or you guys. But she insists on going to a mechanic who never even turned a wrench on this car before he did hers.
sounds like a nasty vaccum leak. Maybe they left a line off or cracked off one of the solenoids under the manifold. THe codes may be related to this but not sure. A low jump idle will be an effect of a leak
Tom |
