Old 11-15-2014, 08:35 PM
Jvan Jvan is offline
master brake cylinder swap
As I started to drive out of my driveway, today, I lost all brakes. I haven't had time to check it out but loss of all brakes is normally a master brake cylinder failure. I have a spare master cylinder from a 05 STI. Will it directly swap to the SVX or even if it fits, is it up to the task of exerting enough pressure to effectively stop the SVX?
Old 11-15-2014, 11:45 PM
Tireiron Tireiron is offline
Re: master brake cylinder swap
ANY leak in the brake system will cause all braking to go out. Check for leaks first and then move on from there with diagnostics.
Old 11-16-2014, 10:17 AM
I'm going to check it out today but I was under the impression that we had a split braking system so that if the front/ rear leaked we would still have two wheels to stop the car.
Old 11-16-2014, 11:09 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
I'm not sure how our brake system works, but when I had a leak in one of my rear hoses, I was still able to brake. It can't hurt to check all the brakes anyway.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 11-16-2014, 02:18 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Lose of all breaking? How about the brake booster, vacuum leak?
Gene and Ben
Old 11-16-2014, 03:40 PM
Jvan,
first check the brake fluid level,
then look for leaks in front of both rear tires.
