Old 05-12-2018, 01:08 PM
Re: Stalls intermittently at stops when warm...
When it's running rough disconnect one fuel injector at a time. If it runs rougher that's not the one. If it runs the same you've found it. It's easier to disconnect injectors and you won't get a jolt of electricity.
1997 Bordeaux Pearl, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V,
Old 05-12-2018, 05:07 PM
irox irox is offline
There is a procedure in the Factory Service Manual for testing coil packs. IIRC it's just about testing the resistance (if it's lower than spec, there's a short, if it's higher than spec, there is some damage increasing the resistance some where).
Old 05-20-2018, 01:52 PM
SacSVX SacSVX is offline
I have yet to test the coil packs but just pondering ideas.
If it were one or more coil packs, wouldn't the car shudder or misfire instead of completely shutting down?
I drove the car today again(i only have time once a week to attempt to work in it) and it was normal at low to moderate throttle for 15 minutes. when the car was at operating temp, i did a full throttle acceleration just to see if I could replicate the problem and that's when the car began stumbling (tach went crazy) then followed by stalling.
Sorry to keep bringing this issue up so thank you all for your help.
Best
