Old 06-30-2013, 08:55 AM
fasteract7's Avatar
fasteract7 fasteract7 is offline
ABS fault code #10 recipients need to apply!!
Had the ABS #10 code come up intermittently but would dissappear with restart of car until last few days when it has the ABS light lite all the time..my valve relay checks out fine, fuses good, power to modulator. Haven't unhooked ABS module and done all the resistance checks yet, did the 2 modulator/pump connectors resistance checks.
Has anyone had this code 10 and found where their problem lay, other than the valve relay ? I am hoping it's not the modulator unit but get the feeling it might be heading that way. ABS LED still blicking out code so think module not the problem.
In a different area, has anyone swapped out the modulator/ABS pump..any hints/problems (mine is a 92)...connect all the hard lines and connect wires/connector and bleed according to Manual..first the primary and secondary bleeders on the unit than all all 4 wheels ?
Feedback will be much appreciated...
