Old 03-25-2013, 05:43 AM
Kiss Me Deadly's Avatar
Kiss Me Deadly Kiss Me Deadly is offline
Send a message via ICQ to Kiss Me Deadly
idle trouble after deep puddle pass
Well, there was a deep puddle on the road which i passed at low speed..
SVX coughed for 2 minutes, then it died, but after immediate start i was not able to raise rpms over 3000 for next 15 minutes. Then the power came back to the car. Next day i replaced with new air filter which was looked like dirty deformed sponge.. Now i have the following problems:
-No warming idle after cold start. It idle constantly at 1100rpm
-High idle. 900rpm at 1,2,3,D 1100rpm on P
-The car driven as usual, no engine power loss
Thanks for help
Subaru SVX LSi `95
Old 03-25-2013, 01:25 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: idle trouble after deep puddle pass
Clean your maf sensor
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 03-25-2013, 09:47 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
what would cause the idle to still be high (1500 rpms) even after car is fully warmed up. No Codes, TPS set to 0.48 volts, 800 rpms idle on select monitor. This occurs randomly, not every time, but more often than not. Also several times the idle went up on its own in park with no one in the car. From 750-800 rpms to 1100rpms. Its the weirdest thing. This has been occuring for the past 1000 miles at least, but no codes, and car runs strong as a bull. All new plugs, coils, vacuum hoses, knock sensors, just about the whole kitchen sink replaced.
1995 POLO LSI 76K MILES SOLD
Old 03-25-2013, 10:11 PM
Coolant temp sensor.
Old 03-25-2013, 10:15 PM
SVX92-97's Avatar
Thanks Icing, I was thinking of that myself. I will replace it and see if that cures it.
Old 03-26-2013, 07:14 AM
dragoontwo dragoontwo is offline
The idle control valve under the throttle body can also randomly do this. If you have it off its easy to clean. Just mark the position of the motor on the end, take it off, spray in the chamber with some non-chlorinated brake cleaner, and rotate the shaft back and forth a few times, and dump brake cleaner out. When you put the motor back on, the valve should snap back into the correct position, and install the motor in the same position it came off in(should have marked it earlier, or you can see where the washers were).
'92 SVX LS Pearl White - 6mt
Old 03-26-2013, 12:28 PM
SVX92-97's Avatar
I doubt its the coolant temp sensor. I replaced it last year, and that was only 2000 miles ago I also replaced the IACV with a supposedly good one I bought on Fleabay. No codes in system, but I was getting codes for IACV before OT did all the work to my engine. I just want this idle issue fixed so I can enjoy the whole car like I should. For example, today I drove 35 miles from startup to work. Stopped at DD for coffee, its idling 1200 in park. Shut off for 3 minutes while I was inside the DD, came out started and now its idling perfect at 750-800. This happens quite frequently where you have to shut the car off for a few minutes and then restart to get a perfect idle.
Old 03-26-2013, 04:00 PM
processengr's Avatar
Hi Dan,
When my TPS was bad, it would do exactly that!
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 03-26-2013, 04:25 PM
SVX92-97's Avatar
Thanks for the tip Gordon. Did you get any codes when yours was bad. Do you have any spare good TPS's around
Old 03-26-2013, 05:24 PM
No codes, but downshifted too easily and held gears too long. I had adjusted the voltage at idle, but had a dead spot. New TPS cured problem in both 92s.
Cheers! Gordon
2018 Tesla M3 30k
Old 03-27-2013, 05:07 AM
Thanks,
clean with Carbcleaner or Wd-40 or whats better? And dry after?
Subaru SVX LSi `95
Old 03-27-2013, 05:57 AM
Pick up some CRC Mass Airflow Sensor Cleaner. Should be able to get it ant Advance Auto, Auto Zone, or Amazon.com.
Spray 10 to 15 spurts of the cleaner onto the wire or plate. Don't scrub the parts; you may break the wire or damage the plate. Allow the MAF sensor to dry completely before reinstalling it in the air duct.
Old 03-27-2013, 06:34 AM
You mean Moscow Auto Parts right.
Don't use WD40.
Old 03-27-2013, 07:17 AM
thanks for the advice, i havent seen CRC is sold here, i think Liqui Moly would be the same
Subaru SVX LSi `95
Old 03-27-2013, 07:36 AM
Key properties for any MAF sensor cleaner would be "Leaves no residue" and "safe for plastics"
WD40 would not be acceptable, in that it leaves a residue.
Cheers! Gordon
2018 Tesla M3 30k
