Old 06-23-2009, 01:02 PM
Gamesy's Avatar
Gamesy Gamesy is offline
ignition relay location?
i've been trying to find the relay for the ignition but cant seem to find it, anyone know where? the wiring diagram doesnt help
Old 06-23-2009, 01:08 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: ignition relay location?
From your other posts on this issue, I wouldnt suspect the relay itself..... if the problem started after removing and installing the transmission, then I would suspect a switch or lead that is disconnected. You made sure the signal wire was hooked up to the starter right? (smaller 12V wire)
Old 06-23-2009, 01:49 PM
Gamesy's Avatar
ya little black rectangle plug that fits on it. so if the cable isnt the issue and the relay is, where is the relay? supposedly under the dash but there really isnt anything to spot... then again i'm not sure what exactly that relay looks like
the term "behind left I/P" keeps coming up but whats I/P?
Old 06-23-2009, 07:28 PM
Gamesy's Avatar
so i got a new ignition relay today and switched it over and still NOTHING
at this point i dont know what to do. if anyone could help me out that would be awesome
Old 06-23-2009, 09:34 PM
kwren's Avatar
kwren kwren is offline
test the circuit out! Is a fool proof way to "guess" what you need to do to fix it!
Keith
Old 06-23-2009, 09:48 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
It HAS to be related to what you just did..... your Park/Neutral switch is probably not hooked up or isnt adjusted or is dirty. If this all started when you pulled it all apart, you have to start there. The other possibility is the ignition switch but having yanked the transmission I would definitely go back over your selector switch again....
Old 06-23-2009, 10:50 PM
Gamesy's Avatar
GOT IT WORKING!!!!!
turns out the bracket on the shifter cable wasnt having it shift to what it was reading. its weird. Anyone need an relay switch? lol
