Old 08-01-2007, 08:19 PM
Originally Posted by nightrider
one quick question if i pull the axel will i loose all my gear oil(i have a wrx 5 speed , if it matters)
No, no tranny greas will come out, as it has an internal seal....
Old 08-01-2007, 09:28 PM
Crazypolo95 Crazypolo95 is offline
95pologreen
Send a message via AIM to Crazypolo95
How much will it cost for a shop to get it in. Also how much would a tune up for a Svx cost form a dealer ship? (spark pulgs, all new brakes fluids,read Diff,trany, and coolent.
Originally Posted by Kelvin
It's a front axle. It's not a big deal. Most any autostore can get one for you. I got one with the lifetime warranty.
Old 08-02-2007, 12:15 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Got mine done pretty cheap!!
Not the best way but maybe not the worst way, maybe the cheapest way.
I got both sides done on my mazda but it's the similar thing. Bought a set of CV boot kits including both sides' inner and outer boots with clamps and greases for only eight dollars(someone I know)
Went to a friend of mine's work place who has the good tools. Took the driveshafts out, clean, check the gears inside(look good), put the new grease in and seal it. No clicking noise till now. Work like new. I was driving with cracked CV boot about 1-2 thousands miles. Now both have been reconditioned. No leak or anything. I have already put 8-9 thousands miles ... still good...I think it will last long. For almost 130K, I still have the original driveshaft. Got both side done about 30mins with an oil change. Charge me $30 bucks for labor. Very happy...can't beat that.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 08-02-2007, 09:20 PM
dmnknightomega6 dmnknightomega6 is offline
Hmm..
I checked mine this morning, This is the boot that goes behind the brakes/hub (if looking from the Wheel) right?
I noticed mine was covered in some sort of oil, I know my Power steering system is leaking oil, Is this Part of the drive shaft assembly? or below it? Leak sources?
It looks like my car is spotting whenever i park after a long drive.
Someone please point out a link for a diagram.....
Old 08-03-2007, 06:59 PM
95pologreen
Hey yeah so i thinking i'm going to buy just the whole axle both right and left.Cuz i think that is something also wrong with my left side so yeah and i think i may be just better .So where would it be better to get them from? i'm thinking of from http://svx-motorsport-accessories.st...rontaxles.html
Old 08-04-2007, 10:22 AM
I usually just get them from a local parts place, usually have a lifetime warrenty, and are close by if yo9u have to exchange it....
But for the best axles, try Raxles(I think that the correct name) out of FL.....
Old 08-04-2007, 11:33 AM
Kelvin Kelvin is offline
Banned
HAhaha. ;D
Old 08-04-2007, 11:34 AM
Banned
Uh, no. Get them at autozone, advance auto, anywhere. They should be under $100 each, and come with a lifetime warranty.
Old 08-04-2007, 11:47 AM
Hop Hop is offline
Classic SVX
They've got them for $80 at advance auto with a lifetime warrantee : http://www.partsamerica.com/ProductD...pe=945&PTSet=A
Is there a difference between 2 & 4 wheel drive halfshafts? Because AP lists diff prices. You can get the halfshaft for the 2wd for $59.
Old 08-04-2007, 12:00 PM
Either will work, but I think the FWD are actually heavier built...
Old 08-04-2007, 12:33 PM
95pologreen
sweet i just may have to get the night. Yes one more thing down on the to do list and now. And a altos to go. ok now tells talk about spark pulgs, all new brakes fluids,read Diff,trany, and coolent fluids and bigger fluid Injector
Old 08-04-2007, 01:07 PM
Banned
Really? That's interesting. There's no way FWD halfshafts would work in the rear, right? Because that'd be ideal for a RWD conversion...
Old 08-04-2007, 07:13 PM
Nope...Rears are completely different.
Old 08-07-2007, 11:23 AM
nightrider nightrider is offline
if the ones for a fwd are stronger and they will work in my awd svx shuold i use them instead will they last longer?
Old 08-07-2007, 01:17 PM
Banned
I doubt it. We don't really have a problem of snapping the front axles on AWD SVXs. If anything, they'd probably just make your car a bit slower due to more rotating mass.
