Old 07-24-2007, 04:39 PM
Crazypolo95 Crazypolo95 is offline
95pologreen
Send a message via AIM to Crazypolo95
wides tire size
right now i'm on some 235/45/17 anyone have anything bigger? getting some new tires and going with 235/40/17
Old 07-24-2007, 04:43 PM
We're running 22" x 11" on 16" rims. SVXride is running 275's I think.
Old 07-24-2007, 06:13 PM
95pologreen
well can i fit a 245/45/17 with drop sprrings?
Old 07-24-2007, 06:22 PM
redsvx's Avatar
redsvx redsvx is offline
Alcyone ... the brightest star
well can i fit a 245/45/17 with drop springs?
Don't know about that but I just put on 245/40/17 Michelin Pilots and I have lots of upper clearance. Maybe just go with the 40 series to be sure?
I test fitted a few on rims first to check for clearance.
92 SVX LS Pearl
94 SVX LSi Barcelona Red
82 Brat 4WD
Bob
Old 07-24-2007, 06:29 PM
95pologreen
i'm going with the 245/45ZR17 Avon Tech M500 Blackwall for $99.00 each that is why i want to see if it is cool. or is that pushing it
Old 07-24-2007, 07:08 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
That's a loaded question that calls for a loaded answer. If you drop a 1/8" of an inch yes, if you drop 4" no. Any other questions!
Old 07-24-2007, 09:00 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
275/45-16 Hoosier R3 on 9 inch wide TSW rims with ~38mm offset -- serious rework of the front and rear fenders required since I don't have coil overs
Just put 255/40-17 Bridgestone 050 (street tires) on 8 inch wide Mustang GT Bullet rims that have 45mm offset. They look like they'd work without reworking the fenders, but then again, I'm running -1.5 degrees of camber in the back and -1.75 degrees of camber in the front.
295/35-17 Hoosier A6 tires on 9 inch wide Mustang Cobra rims with 26mm offset is next in the works. They'll be going on SVreX II, since it has GC coilovers on it.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
