Old 05-17-2005, 04:38 PM
KCROGUEDOG
O2 layout
i have a 97 and the chiltons book i got for and with the svx in it reads to 92 - 96. i was wondering if any one had the decodation for the wire harness to the 3rd o2 sensor. which color is ground, heat, 2 signals, power? i dont know how many wires they got i need to raise it up to look. im hooking up the o2 simulator to kill the ce light problem i got do to no cats.
Old 05-18-2005, 08:17 AM
KCROGUEDOG
any one know the color codes come on
Old 05-18-2005, 09:17 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Rule of thumb: Whites are heater, black is ground, red is signal.
Old 05-18-2005, 09:54 AM
ssnsltd's Avatar
ssnsltd ssnsltd is offline
That's gona leave a mark.
I just had to pull mine when I swapped out the propshaft.
I thought mine had two black wires and a white wire. I suppose one could have been a VERY dark red, but I don't think so.
David
96LSi 102k Laguna Blue
95 LS-L AWD, Safety package, 140k Polo Green
the Chick Magnet:
91 Justy GL EFI 4x4 154k (new motor @120k)
90 Yamaha V-Max
82 Yamaha XJ650LJ Turbo
My Diver Propulsion vehicle:
88 Jeep Cherokee 160k
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
85 XT AWD/4x4 Turbo Space Blue
Old 05-18-2005, 10:33 AM
KCROGUEDOG
beav what is the power 12v color
Old 05-18-2005, 10:34 AM
KCROGUEDOG
ss did yours only have three wires for sure
Old 05-18-2005, 01:28 PM
Beav's Avatar
Not as old as Randy
Another rule of thumb: Three-wire sensors - Paired colors are heater circuit, odd color is signal.
Old 05-18-2005, 03:04 PM
ssnsltd's Avatar
Definitely only three wire, all three sensors are three wire. They have a four wire plug, but only three (3) wires.
David
the Chick Magnet:
90 Yamaha V-Max
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
Old 05-19-2005, 12:01 PM
KCROGUEDOG
ok i need help i got 3 wires but no power wire i think. look at these instructions on this site and see what i mean. positive splices to power and ground splices to ground. heater is untouched and for the signal it is cut and left for dead the simulator is connected to sig wire to trick ecu. www.o2sensorsimulator.com
Old 05-19-2005, 12:03 PM
KCROGUEDOG
cruise to install and see if some one can help me out. 3 to connect only 3 to work with and one is untouched this is the 3rd o2.
Old 05-19-2005, 12:13 PM
crimsonnblue
just had to ask.
are u from kansas city???
Old 05-19-2005, 12:23 PM
KCROGUEDOG
yes i get to move back in aug.
Old 05-19-2005, 01:04 PM
ssnsltd's Avatar
hmm. They don't cover three wire instalation. Looks like you will need to email them. Interesting product, if you would let us know how this works out. . .
David
the Chick Magnet:
90 Yamaha V-Max
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
Old 05-19-2005, 07:39 PM
KCROGUEDOG
Your car does not monitor the Heater circuit. The wire labeled Heater is used to power the sensor to pre-heat it and send a signal to the ECU. In this case, if the heater wire shows +12v only when the ignition is on, use it as the power source to the sim.
this is the response i got so info for all. i still have yet to install. ty for all the help and i will update after intall.
