Old 07-25-2003, 09:27 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Wouldn't it be easier to get to from under the car?
Dayle - thanks for taking the picture, I didn't even realize there was yet another PS hose back there.
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-25-2003, 10:09 AM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
I think I tried, but wasnt too accessible....
but if you do it that way....lmk
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 07-25-2003, 10:49 AM
SVXRide's Avatar
I should have mine up on a lift in the next two weeks (finally getting around to installing the powder coated calipers from Doug! ) so I'll take a look.
Old 07-25-2003, 12:03 PM
DavieGravy DavieGravy is offline
Just all you need is a small nut driver or screwdriver
to loosen the old clamps. I took out the stock air tube
to be able to get in there a little better, its down pretty
far and outta the way. I actually ended up using a utility knife
to cut it in half and then removed it in 2 pcs's.
Slid on the new hose, tightened the clamps and was done.
Good luck
Mine seems to look a little bit different than yours. Is it this hose that says power steering on it or is it below that?
Thanks.
Out for good.
Old 07-25-2003, 12:14 PM
that there
Thanks.
is the other hose, the high pressure hose...
that one also has issues over time....
harder to change and
cost more too....
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 07-25-2003, 12:41 PM
I see exactly which hose your talking about now. I felt up and down it, as well as the other hose I showed you, and didn't feel any wetness or cracking, but who knows. I did, however, notice a straight, rigid slit along the top part of this hose. Not sure if it's supposed to be that way or not. Could that be the cuase?
Out for good.
Old 07-25-2003, 12:58 PM
Sounds like the culprit, You didnt fix it yet, thought you did?
Have someone start your car and turn the steering wheel lock to lock while you have your hand on that slice...
You should feel some ps fluid leaking out....
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 07-25-2003, 01:58 PM
Acutally, I went out and had a second feel around and I don't think that slit is really a slit. I think it's just a normal for that the hose. Plus it feels clean.
What I noticed, though, is that the hose you were talking about (the return hose) feels really dirty and gritty, so I bet there's a pinhole leak somewhere and that's the culprit.
Thanks again for the help.
Out for good.
Old 07-25-2003, 09:10 PM
cool
Im sure thats it....I just ordered a few of those
hoses for stock, cost about $5 ea...
Let me know how yours comes out..
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 07-26-2003, 12:30 PM
I will. Thanks.
Out for good.
Old 08-02-2003, 08:14 AM
CigarJohnny's Avatar
In a word? No. I'm doing mine now and it is very easy to access everything from above when you remove the intake tubing. Not too easy to see what you are doing but you can feel your way through it easily enough. My difficulty right now is getting a replacement hose. Damned dealer parts counter is closed on a Saturday morning. Now I still have to wait until Monday morning unless I can find a working substitute at a regular car parts house.
Old 08-02-2003, 11:43 AM
You can use rubber transmission/fuel line, maybe 3/8" ID
for the meantime, it wont be Pre-formed like the OE
but if you dont kink it it can do for now if you have to
drive the car.......and you can change it later when you
get the correct one.....
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 08-02-2003, 02:39 PM
The job is done and she runs great. No leaks. I called a few parts stores around here and they simply list 3/8" ID hydraulic hose as the replacement. Cost with new hose clamps was only about $2 and lots of cussin' while trying to push the line on the pipe ends. There is no kinking in the hose and I think it will be fine for some time to come. After the PITA it was to push the lines on (especially the lower one) I am in no hurry to make extra unneeded work for myself. First sign of trouble, however, I will be happy to put a pre-bent hose on her.
