a few trannie swap Q's
i'm getting ready to put a legacy 4eat into my svx next week will the stock axels fit into this transmission, and is the speedo in sxv.s cable driven or electric, any other common issues i need to worry about, aside from the matching rear diff have that
1991 xt6 eg33? 1993 gc track car |
The axles fit
The speed sensors are different, but attach to the same spot on the trans, you'll need to remove the electronic sender from the top/right of the front diff and put it where the speedo cable went on the Leg
Also, I sort of remember having to swap dipstick tubes, but I'm not sure which swap that was during, so check that out.
You'll want to use the SVX TC, but since the SVX trans was fried, at minimum you'll want to flush it out very well.
A 4.44 TQ is ok with a 4.44 trans, but I would bet money a 4.11 TQ wont last very long at all.
TZ102ZACAA-DR 161263 I CAN'T FIND ANY THING ON THIS TRANNIE, SIGNS POINT TO IT BEING A 4.44, BUT IT MAY BE A 4.11 it's going in monday so i could really use the info because i have no clue
Did you get the diff from the same car? Or, did you pull a 4.11 rear from another car?
To use the Legacy TC, you'll need a Legacy flexplate....just FYI.
And you HAVE to pull the gears out of the rear diff, so count the teeth on the ring gear, and divide that number by the number of teeth on th epinion gear, and that is the Gear ratio... (since you already told me that the tranny and rear diff came out of the same car) And make SURE the TC is seated all the way befoe installing the tranny
