Old 05-30-2005, 04:50 PM
drivemusicnow's Avatar
drivemusicnow drivemusicnow is offline
Poor College Racer
Send a message via AIM to drivemusicnow
OT: eclipse help
Sooo I'm replacing the fuel pump in my eclipse, and i run into a problem. There are 6 bolts holding the fuel pump assembly to the gas tank. 3 of the nuts come right off. 3 look to be smaller and decide not to. Soo, i go through every socket i have... its larger than a 7 mm, and smaller than an 8. and its larger than a 1/4 but smaller than a 9/32... soooo on to the vise-grips. break one of them clear off, which works for me at this point... but the other two just seem to bend and change shape without ever breaking or moving.
So heres my question... how do you break off a nut like this... without throwing a spark??? seeing as how there is gasoline vapors in the area, sparks seem like a bad idea to me right now.
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 05-30-2005, 05:34 PM
black beast black beast is offline
Back Road Blazer
Send a message via AIM to black beast
Liquid anything, nitrogen, oxygen, any gas that is froozen to a liquid, sray it on the bolt and tap it with a hammer. Ask around, I can buy Liquid Nitro down the street from me, it cool stuff. be sure to only spray the bolt, or the whole gas tank in that area go crash!
-Chris
'94 ebony pearl, with orange "silicone" hoses, painted beauty cover, Tom's Intake, Dayles Cold air intake; with HKS mega suction foam air filter, 3in header back exhaust, STI ground wires, euro front fascia, euro front grill, reactive 17in wheels, Nitto Invo's, Drilled and slotted rotors, stainless break lines, Koni strut inserts, Drop springs, 5MT, shotshifter, Clutchmasters clutch, ACT prolite flywheel, EL Glow gauges, The ECUTune stage 2. To Do: Cams, port and polish, etc.
Old 05-30-2005, 07:51 PM
KCROGUEDOG
that computer air dust remover if shaken and held upside down can freeze and burn skin . just a thought.
Old 05-30-2005, 08:47 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Did you try spraying it with some type of liquid wrench? Let it soak for awhile? tap around it lightly to lossen the rust? Try turning clockwise a little before loosening it? If all else fails, try cuting it with a hack saw. Cut it straight down on one side of the nut (close to the bolt as possible). Once you do this, you should be able to pry off the remainder of the bolt. ( they also have a tool that breaks off nuts, it cuts into it until it breaks apart, I don't remember the name ) Good luck.
Display Modes
