Old 03-28-2002, 01:32 PM
Brian Steel
5 speed quarter time
After installing a new ACT pressure plate in the SVX five speed and using a Gtech Pro and with a less than extreme launch we recorded a 15.33 quarter mile time at 93 MPH. I have no idea how accurate these things are but the time was about what I expected. I figure if I wanted to thrash it a bit harder, I might get it into the 14's. The engine is completely stock, 132K.
Old 03-28-2002, 02:02 PM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
Brian-Did you run times on the car(or other SVX) with the 4EAT? I had a G-tech and my aggregate 1/4 mile time was 15.34, before the nitrous of course. My car hesitates pretty good from a standing stop. Just thought you might want some numbers to compare with. Keep up the good work.
Stephen
92 Ebony - Level 10/n2o REAR-ENDED
92 Teal - painted yellow/4.11 5spd/n2o SOLD
92 Claret - 4.44 SOLD
94 Barcelona - FWD SOLD
92 Ebony - 3.90 SOLD
94 Laguna ROLLING w/4.44s/Ecutune ECU +TCU/STI springs/Infiniti M45 rims
Old 03-28-2002, 03:31 PM
Lowered SVX
i ran the quarter here in memphis....
when my car was stock and i put up 16.5 and 16.6 numbers at about 86-87mph.
"Too much fun to drive!"
Old 03-28-2002, 04:37 PM
Brian Steel
Stephen
Stephen,
I intend to try a run with the same unit on my Teal 92 with the Auto. 110K and all stock.
Old 03-28-2002, 08:35 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
Re: 5 speed quarter time
Hey Brian......I ran my other Claret SVX here in Tucson last yr..very warm out, 1400 ft elevation and got a best of 16.3
That was with an upgrades catback and a K&N airfilter.
Thats a respectable time on a Gtech. Ill take mine to the track when I get it back from you and let you know what I get here (as is stock) and then with our upgrades we offer. Also with and w/o a ZEX nitrous kit.
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 03-29-2002, 05:42 AM
Brian,
Did the ACT clutch set-up elliminate any clutch slipage on a hard launch?
I'd like to know if it did, so I'll know if I should invest in one.
Thanks,
Old 03-30-2002, 01:17 PM
Brian Steel
Originally posted by huck369
Brian,
Thanks,
Huck,
The stock Impreza clutch was not able to hold the torque of the SVX engine, the ACT clutch does admirably. As far as eliminating slippage on a hard launch, my thought is that if you stomp the throttle hard enough and let out the clutch fast enough and the road is dry, somethings gotta give and I really don't want to find out if the clutch is stronger than the next weakest component since I fear what part that might be.
Old 03-30-2002, 04:59 PM
Re: Re: 5 speed quarter time
Huck,
That is all I wanted to know, with the cheap clutch that I've got in mine, if I try to take off even kind of hard it slips, but on normal take offs it does fine, once it's rolling, I can open it up without it slipping, just no hard launching.
I don't want to find the weakest link either
Thanks for the heads up,
