Old 03-13-2002, 05:15 PM
immortal_suby's Avatar
Thread Killah
transmission weight
Anyone know how much our tranny weighs?
The trucking company called and they are delivering tomorrow but they have no way (forklift) of gettin it off the truck.
Could 2 people with no fear of back problems lift it?
Locker Link
2015 BRZ Limited 6MT
Old 03-13-2002, 05:18 PM
Green1995SVX
Very good question... I've always wondered that. <waits for response>
-Mike
Old 03-13-2002, 05:26 PM
wawazat??'s Avatar
Yeah, I'm still around
Re: transmission weight
Trucking company should know EXACTLY how much it weighs. They typically charge by weight.
Todd
Down to none
Old 03-13-2002, 05:41 PM
Thread Killah
Talking
Reddaway trucking - they did not know. I guess I should eat some wheaties tomorrow morning.
BTW -just how hard is it to install one of these without a lift?
Locker Link
Old 03-13-2002, 05:47 PM
wawazat??'s Avatar
That depends
on how much you hurt yourself getting it outta the truck!
Rent a transmission jack at a local rental place. I've used a floor jack in the past but it was scary!
Remember, don't be a TOOL, use the right TOOL! (8th grade shop teacher wisdom)
Todd
Down to none
Old 03-13-2002, 06:41 PM
EverclearAtMSU
trannies are usually pretty heavy to begin w/. however when working for my uncle we would lift them on a daily basis. So if you've got some pretty strong people, it shouldn't be a problem. My advice would be to get a few skateboards and a peice of plywood, stick like 3 or 4 skateboards under the plywood and the tranny ontop. the board will distribute the weight pretty well. you'd be suprised at how much those things can take. I only need 1 for my engine and tranny in the 914
Old 03-13-2002, 07:25 PM
I'm guessing about 200 lbs, after having mine out a couple times, the manual weighs about half what the auto weighs.
By my scales(lifting it in and out) anyway.
Old 03-13-2002, 08:44 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
160 lbs is what mine weighted. Two people can lift it easily.
'20 Honda Ridgeline
http://www.x35design.com
Old 03-14-2002, 02:52 PM
Thread Killah
thanks guys!
I'm eagerly awaiting its arrival - should be here within a couple hours.
Still debating whether I should try to put this in the car myself opr take it to a shop. I've done trannys before, but something tells me this one will be quite a bit harder.
Locker Link
Old 03-14-2002, 03:04 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Sorry, I joined this thread late. When I had mine shipped from D.C. it weighed in at 250 lbs. The guy was going to ship it UPS, but, they had a 200 lb limit. He wound up having to "freight" it instead.
Randy Johnson
Mike Davis -- at Reading VI
Old 03-14-2002, 03:07 PM
Lowered SVX
immortal......
take your car and tranny to a shop. save yourself the headache and future potential problems.
good luck
"Too much fun to drive!"
Old 03-14-2002, 03:10 PM
Godzilla
Re: Re: transmission weight
Well, with my V-8s, I fabricated a cradle out of plywood and 2x4's to hold the tranny in place and then put that onto a floor jack and lift it into place with the floor jack from underneath WHILE the front of the car is on jackstands (under the frame). Dont see why this wouldnt work with the SVX either. Sure would be a damn sight easier than borrowing the skateboards from all the kids in the neighborhood. While im thinking of trannies, why doesnt someone make a transmission pan that is deeper and has air tubes going through it to help cool off the fluid in the pan? They are common items for V-8's, and there seems like no reason (short of clearance issues) they wouldnt make one for the SVX.
Old 03-16-2002, 07:30 AM
Thread Killah
The driver and I were able to pick it up off the trailer (those things are tall!) and set it down on my floor creeper to roll it in the garage. It was scary seeing an 18 wheeler do a U-turn in my cul-de-sac but he made it. My back hurt a little yesterday. They had 300lbs written in as freight charge but I am guessing it is closer to the 160lbs that Stevesby quoted.
Locker Link
