True or False? Oil Pan
Is the SVX oil pan magnetic on the inside? I read this in my replacement SVX parts manual. If so, what would be the purpose of a magnetic drain plug then? Any insight?
Re: True or False? Oil Pan
I've heard of a magnet installed in the Tranny pan to collect small metal particulates, but, havn't heard of it in the crankcase pan. Guess they could have installed one in that pan, for the same reason. If you ever have the tranny serviced (to the point they drop the pan) make sure they clean the magnet. Again, dunno about the crankcase pan. EDIT: I just looked in the FSM. There's no mention of any magnetic properties in the pan, nor, does it show the position of a magnet in the pan.
Randy Johnson 3rd Registered Member 02-21-2001 First Member to Reach 10,000 Posts First to arrive at the very first Reading Meet Subaru Ambassador 1992 SVX PPG Pace Car Replica 110+k 1993 White Impreza L 240+K miles 2001 Legacy Outback Limited Sedan 250+K miles 2013 Deep Indigo Pearl Legacy 3.6R 49+K miles "Reading is my favorite Holiday" Mike Davis -- at Reading VI Last edited by Aredubjay; 03-06-2004 at 03:14 PM. |
I'll find it again, but it was the crankcase pan.
As Randy said, there is a magnetic plug in the transmission that's separate from the drain plug.
And the drain plug in the oil pan is magnetic. The oil pan can't be magnetic only on the inside since the thing is a one piece metal pan. I tried holding a screw driver up to the pan - it's not magnetic on the outside - so not magnetic on the inside. |
