Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania
Old 11-14-2016, 12:53 PM
Re: Manual transmission causes crankshaft wear!
Originally Posted by TomsSVX View Post
There are two switches on the trans. One is the reverse switch which we all use for reverse lights. The second is a neutral indicator for cruise control. It is open in neutral and closed in gear. You must use a relay wired to the 87a terminal to reverse this in order to act as a neutral safety for the starting circuit. Or just hardwire the circuit. Either way you lose cruise control.
I never use that switch for neutral, I wire the neutral wiring to the clutch position switch on the pedal, so that when the pedal is depressed, it thinks it is in neutral, thus cutting off the cruise control when you push in the clutch...plus you have to press the clutch to start it, just like a factory set-up should be....but the cruise control works fine this way.
Old 03-25-2019, 07:13 AM
So to revisit this, is it safe to just start the car in neutral with the clutch depressed or is wiring it the way Huck recommends the best way?
I assume wired in the say Huck suggest you would still want to start in neutral?
Old 03-25-2019, 07:34 AM
If wired the way in my write-up, then it doesn't matter if its in gear, or neutral, as when the clutch is depressed, the transmission isn't engaged...
My Current 5-Speed has been running this way for about 13 years with no issues
Old 03-25-2019, 08:55 AM
Awesome thanks.
