Tire sizes stock wheels
I want to buy a set of snow tires this year. 97 stock size is 215/55/16 and 92 stock size is 225/50/16 but what other sizes will work? Anybody using 205/60/16 or other sizes?
They would be on stock wheels and stock suspension.
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
Re: Tire sizes stock wheels
Narrower is better. 205/55/16 for me.
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. |
So 205's work fine on stock wheels?
One the low end it looks like general Altimax Artic and Goodyear Ultagrip Winter. A little more money I can get the Dunlop Graphics. Any recommendations as to brand?
Agreed, narrower is better for snow. I went with 215/55/16 but I can't remember if there was a reason I didn't go down to 205/55/16 or 205/60/16. One possible reason would have been rim width. Each tire can fit on a finite range of rim widths. If you look up the 205/55/16 Blizzak on tirerack.com they have a specifications tab that will tell you the rim widths you can safely use. I think one other reason was that I wanted a slightly larger diameter wheel to make the speedo a little more accurate.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
I have Nokia Hakapoliitta which I think are great. Have had 2 sets.
I ran 205/55/16's every winter with the SVX on the stock rims. Never an issue.
They arrived yesterday. I went with 205/55/16, very curious to try them out, winter should fun this year!
You're going to love it. The only thing that can stop you is if the snow is up to the hood!
The Altimax have good reviews, you should be happy with them. |
I see holes for studs, are you?
1995 POLO LSI 76K MILES SOLD |
A little early, but figured I would put the snows on before it got much colder. They are 205/55/16. The car actually feels a bit higher as a plop my butt in drivers seat.
Now it's time to get the those ski tuned up and hope for a skiers winter. SVX92-97 yes the tires have holes for studs, but I am not planning on having them studded. I miss seeing my BBS on the car already.
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 Last edited by Sean486; 11-10-2013 at 02:20 PM. |
I've been running three sets of snow tires each winter for years on my Pearlie, Christine and Di's Silver.
An SVX with snow tires goes better than my Military 3/4 ton Suburban 4WD, Chevy 3/4 Silverado 4WD on snow tires. Subies RULE (on snows)!
Looking forward to it, last year with the all seasons it wasn't getting much grip in the snow. Even with the AWD it felt slippery.
Thread Tools | |
Display Modes | |
