Old 03-11-2011, 12:46 PM
nexus_7 nexus_7 is offline
It sounds like my rear brakes are dragging...
how can I confirm and fix? or other ideas?
cant tell if it is the parking brakes or the normal ones. Any help would be great.
Or like I said other ideas?
Thanks
Greg
Old 03-11-2011, 07:52 PM
Philly0810 Philly0810 is offline
gotta love an svx!!!
Re: It sounds like my rear brakes are dragging...
Hey, does it feel like your brakes are dragging or just sound like it? It might be your wheel bearings. (These cars are prone for bearings). They make a humming noise and the faster you go the louder it gets.
Old 03-11-2011, 08:00 PM
Heat Seeker WS6's Avatar
Heat Seeker WS6 Heat Seeker WS6 is offline
Were your brakes done recently? if so, maybe the caliper is hung up 'compressed' and it may need greasing
Learning the ways of the SVX... One bolt at a time
Old 03-12-2011, 11:02 AM
when I jack the rear of the car up and spin the wheels I hear and slight hiss or grind or what ever you want to call when brakes are rubbing.
I did the pads and rotors last august/september. and I did the wheel bearing slightly before that.
I repacked them my self and I think they are good.
It really sounds more like brakes rubbing. I guess I will just pull the pads and see if i still hear it.
Greg
Old 03-12-2011, 11:55 AM
Clean and re-grease the caliper pins while you're at it and make sure they are floating freely. Sometimes the dust shields get bent and will rub lightly also.
Old 03-12-2011, 06:16 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
I had both rear calipers fail on me last fall and it happened 2 weeks apart from each other. They were locked and luckily I had slotted rotors that didn't warp. I bought reman calipers and problem was solved.
Check your rims immediately after you drive..touch them and you can feel the heat if they are seized. Mine also had a burned rubber smell when the problem was happening, but oddly nothing was melted.
1995 Subaru Svx L / AWD
Old 03-13-2011, 12:00 PM
SVX33 SVX33 is offline
It's probably just rust and dirt in the parking brake drum. As you drive off slowly, pull the handle to see if the noise goes away. I do that every time I hear the same sound.
Old 03-13-2011, 08:29 PM
good ideas...I will try them tomorrow.
Old 03-16-2011, 02:58 PM
well, my parking pads are warn out...AND my passenger rear bearing is SHOT again. the place will cover the labor though at least.
Its a timken and I repacked it my self. guess they pressed it in wrong. Ugh
