ABS SENSORS !!!!help please
Does any one know the best way to get abs sensors out of the spindles without breaking them..........i need to change my front bearings, they are real bad and the housings...... i have all new housings and im just waiting to put them on but i dont want to break the sensors off of the old housings, if you could help me it would be much appreciated
Don |
Re: ABS SENSORS !!!!help please
the coils inside the sensors are fragile and if you use a BFH to get them out, you're sure to break them. A new sensor will run you about $110.. not pretty. Since we broke mine when removing it (NOT required for the replacement of a CV axle, though Chilton's would like you to believe otherwise), I can't tell you how to do it without breaking them, but I'll just warn you to be careful.. -adam |
Don, where have you been? I havent seen you arond town at all this week. Give me a call today. I found that trunk reliese handle for you.
Mike |
I asked the same question a month ago on the rear spindal housing. (for the rear bearings) I was told to get PB liquid at my local automotive store and after spraying the sensor remove. One person told me that he used a chisel and rocked the sensor back and forth until it came out. I haven't tried mine yet but this is what I was told.
Blue |
