Starter relay question
My 92 LSL has started having the intermittent start problem.
I've read most of the threads on the relay mod and will do it when the weather permits. I would like to know if the relay in question is the starter inhibit relay? If so, does anyone have the oem part number for it? Thanks.
92' Ebony. Magnaflow exhaust, tinted windows, STI wheels, 97' grille, Bontrager Works SB, ECUtune transaxle and TCU. 77' IHC Scout SSII |
Re: Starter relay question
It's just a regular relay, nothing special that you need part number. Should be able to tell your parts person you need a Bosch relay with five blades and be fine. You really only need four but the original has five.
This was posted about 4 years ago for the relay under the dash;Bosch part# 0332204150.
However Summit racing says it is unavailable and wants to replace it with Bosch Part # 0332209150
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 Last edited by Sean486; 01-05-2015 at 11:24 AM. |
Thanks.
Now I just have to make time to work on it.
It's not plug and play? Is there how-to?
http://www.svxworldforums.com/view_t...=Starter+relay
This should help. Really what you do is mount a relay Remove the wire on the solenoid and hook to relay Run a new wire from relay to where you just removed that wire from. Add 12 volts to the relay.
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. |
