Help needed in running wires from trunk to battery
Hi,
I have ran wires from the trunk to the dashboard through the center console. i am not having any idea on how to run those wires to the battery from there so that i can make a connection to the battery +ve. thts the only remainin work in installing my audio system. Please gimme some suggestions on running them upto battery as soon as possible. Pavan. |
Near the gas petal there is a large grommet with a large bundle of wires going through the firewall. Pop that out and run it through there.
P.S. It's probably easier to run the wire from the battery to the trunk, not trunk to battery.
-Steve Member #895(the member formerly known as BurgundyBeast) 01' MSM Lexus IS300 |
Pavan. |
Hi BurgundtBeast,
I am not able to identify that firewall which u r talkin about. Can u tell me in detail how i have to run my wires to the battery please. From the engine side i am able to see 2-4 outlets of wires with out any opeing in them. But really i am not getting from where i have to run the wires, thts the only work remaining. Anyone plz. help me on this issue, this is my first attempt in doin work on my own... Thanks, Pavan. |
I ran mine down the driver side fender well just behind the small panel and under the driver door sill there is a hole right next to the battery so it comes out pretty clean.
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. 92 SVX LS-L Perly ~186k R.I.P. 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver |
Thanks, Pavan. Last edited by pavanbabut; 11-23-2004 at 07:04 PM. |
I ran mine through the passenger's side. There is a huge grommet on the passenger's side firewall (shared by the air conditioning lines, I think.) Get an pointy stick, tape some rope to it, soap it up (to make it slippery,) and stick it through the grommet. It'll come out just behind the heater box. Tie or tape the rope to your wires and give a good tug.
Also, I recommend running the wires down the side of the car, not the center. Either will work, but the side seems to work best. |
Thanks, Pavan. |
i will try urs too and let u know... thanks, Pavan. |
Here's the best pic I have from my existing catalog of pics:
thanks a lot David.. I got an idea on seeing this i will try it today....
Pavan. Last edited by pavanbabut; 11-24-2004 at 02:57 PM. |
Hi david,
i figured out those outlets but mine are all sealed...should i have push through them and see them from inside or is there any other easy way to do this.... Pavan. |
It does pop out. You could try drilling a hole through it. When I had my stereo installed they shoved the wire through the same hole as the throttle cable. (BAD)
Mine now runs through this large hole along with all the other wires. It also runs down the center console. My RCA cables run along the driver's door sill to my amps in the back.
