Idle Issue, now hard shifting after cleaning throttle body
Hey guys,
When I start my car, the idle goes wayyy up, then down, then up etc for about 10 seconds. Any time I come to a stop sign or go through an drive-thru etc, it idles very rough and has died a couple time in the laft 4 months. My thought was spark plugs and/or ignition coil(s), but I'd like to try anything else before spending money on something that might not be the problem. Anyone have an idea? I saw maybe cleaning the throttle body might help... Last edited by kis86; 04-19-2007 at 08:19 AM. |
Is it throwing any ECU codes?
Before you start throwing parts at it, make sure the TPS is adjusted properly, that cost nothing but 1/2 an hour of your time There are instructions in the "How To Document's" up top ^^^
I agree, i would check TPS, see if your throttlebody is clean, if all that checks out make sure your air filter is ok, sounds like it's starving for oxygen one way or another.
I just had this happen on my '92 yesterday. I was checking the adjustment of my TPS. When I finished I started the car and the idle immediately shot way up, then it dropped down real low, finally it died. I thought I had messed up the TPS adjustment. The problem was due to a large hose that I had pulled off the throttle body to get better access to the TPS. I forgot to reconnect the hose.
Reconnecting the hose fixed the problem. Check all the hoses around your air intake, throttle body, and intake manifold. There's a bunch of them and the ECU is not happy when it gets big gulps of air, and it's not expecting it. Good Luck
- Jim '02 Outback - Wife's car '96 Legacy Wagon - Son's car '95 Legacy Sedan - #5 Daughter's car '93 Impreza Sedan - #4 Daughter's car '92 Claret LS-L - My car ____________ TOTAL = 595,000 Subi miles |
Grr
Well, I cleaned out the throttle body and now have a new problem. First, I noticed the idle is way up now. In park, it's at 1000. In gear, it's at 1500 rpm. I used to have a problem with shuddering when letting off the gas, and that actually went away.
However...! I now feel like my transmission is going to break every time it shifts...it's shifting extremely hard. Any idea why?? I checked, and rechecked my hoses to make sure I had them all on. All the bolts are tight...Check engine light came on for about 10 minutes, then went off. Checked tranny fluid, and it's good. Checked to make sure everything is plugged in tight and in the right place |
I had this problem for a while and just fixed it. I had pinched a some of the rubber intake when installing it on the throttle body. And I also had 2 cracks in my plastic intake that I fixed. Idles perfect now but Id clean the MAF and make sure theres no air getting in past the MAF through a leak or crack.
[SIGPIC][/SIGPIC] STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit. |
