Old 06-25-2013, 01:49 PM
The Molinator
Crow's Feet.. LeVeRaGe???
Does anyone know the actual engineering physics behind calculating how much torque would change (decrease) to equal the value for a given nut/bolt.. if I use a Crow's Foot on a nut .. rather than a direct access socket?
In other words.. If I can't get good straight access to torque a nut (like motor mount nut) at a fairly tight torque value (61 ft-lbs).. and I use a Crow's Foot socket-wrench to develop straight access (to avoid slipping/stripping nut) .. How much decrease (%) approximately should I apply to the normal torque (61 ft-lbs).. to compensate for the approximate 1" lever the Crow's Foot gives to the nut?
I would guess-ta-mate around 50 ft-lbs ??? Whaddayathink?
Thanks, Jim
Jim
Old 06-25-2013, 02:29 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Re: Crow's Feet.. LeVeRaGe???
Practice on another bolt on your workbench. Torque the bolt with a straight socket, then torque with the crows foot untill it matches the torque value.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 06-25-2013, 02:35 PM
If you are able to torque the nut with the crow's foot at a 90 degree angle to the head of the torque wrench, you should not have to correct.
Old 06-25-2013, 02:56 PM
dannmarr's Avatar
I work for my SVX
Because the center of rotation is different, there will be a small difference in torque value. There is a formula for this, do a search on the internet.
Subaru SVX for fun
Old 06-25-2013, 03:36 PM
I sent an email to my brother, retired Technical Director of GM Motorsports. He knows every formula known to mankind.
It appears to be quite simple if this info from The Net is correct.
desired torque x torque wrench length over
torque wrench length + crowfoot length = torque wrench setting to obtain desired torque
There is also this calculator:http://www.cncexpo.com/TorqueAdapter.aspx
Old 06-25-2013, 04:35 PM
The Molinator
Thanks..
That seems to make sense.. .
61 x 18 = 58 for motor mount nut
18 + 1
P.S. Obviously not critical here.. I just dint wanna twist off the mount stud.. or strip .. so I could buy another $180 MOUNT!
Jim
Old 06-25-2013, 07:18 PM
Confirmed by my genius brother by email. And yes if the crows foot is at 90 degrees the effective length of the handle is unchanged and so the torque setting.
Old 06-25-2013, 09:01 PM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
Should've bought a Group N STI or regular Impreza mount.
Only requires slight bolt hole modification and is 1/3 cheaper than stock.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
