Old 04-24-2013, 01:32 PM
Need help on OEM strut part #'s
I am going to put OEM struts on my 92 SVX.
When I look up the struts on subaruparts.com, it shows 2 part numbers for each strut..
Front
Right:
20311PA000 Pt830593 Strut Cp
20311PA001 Pt830593 Strut Cp F
LEFT:
20311PA010 Pt830593 Strut Cp
20311PA011 Pt830593 Strut Cp F
Rears
Right:
20360PA001 Pt840593 Strut Cp R
20360PA000 Pt840593 Strut Cp
Left:
20360PA010 Pt840593 Strut Cp
20360PA011 Pt840593 Strut Cp R
When I look up struts on liberty Subaru they say they have 2 front left struts also, but they don't give part numbers..
Theirs say:
Strut from 9/92 Left
Strut to 9/92 Left
But they don't have a front "to 9/92 right", or either rear "to 9/92"..
So I guess what I need to know is can I use a "From 9/92" on my 92?
Or am I just SOL because I have a 92?
The part numbers the mechanics computer spit out to him are a match for the "From 9/92".
So I just need confirmation that they are going to fit before I order them, as my 92 has a manufacture date of 8/91..
Also, does anyone know if liberty Subaru in NJ still does discounts for SVXWN?
Old 04-24-2013, 04:14 PM
Re: Need help on OEM strut part #'s
The part numbers for the strut assemblies are 20311PA001 for the right front and 20311PA011 for the left front.
The right rear strut is 20360PA001 and the left rear strut is 20360PA011. These are cheaper.
The front struts have been modified to accept the new upper strut mounts, which were a problem in the early 1992's. You will have to replace these as well. The part numbers for these 20320PA011. All the new strut mounts have been modified
See this TSB
http://members.tripod.com/quick_svx/.../42747818.html
Old 04-24-2013, 04:45 PM
So your saying as long as I have the new mounts, the "From 9/92" will work?
Those are the ones in stock.
Old 05-03-2013, 03:30 PM
Ok my parts are all finally in.
There has been debate on some of the numbers on struts and I would like to add mine to the debate.
Tag:
Strut:
Tag:
Strut:
Tag:
Strut:
Tag:
Strut:
Rear Mounts:
Looking at the dates on the struts themselves, assuming they are YY/MM/DD, they are a few days before the stickers on the bag.
Which would make sense seeing they are made before they bagged and tagged.
Looks like they made a new run of rear struts in 2011.
Looks like they made a new run of fronts struts in 2012.
Parts purchased from Liberty Subaru in Emerson NJ.
Fronts were in stock, off their shelves.
Rears came to them via UPS from Subaru of America Indianapolis.
Old 05-03-2013, 03:41 PM
This is very encouraging news.
Old 05-03-2013, 03:42 PM
These came in today also:
QS components kevlar/teflon Rod ends for nevin's rear swaybar:
Maybe I can finally not have a rattle in my car once I have all this put in. :-)
Old 05-05-2013, 11:44 AM
Here is the info on the struts I ordered:
http://libertysubaruparts.com/
Liberty Subaru in NJ is 20% off MSRP on SVX parts.
20311PA001 <-Front Right Strut $139.96
20311PA011 <-Front Left Strut $139.96
20360PA001 <-Rear Right Strut $167.96
20360PA011 <-Rear Left Strut $167.96
20361PA000 <-right rear mount $79.96
20361PA010 <-left rear mount $79.96
Sub total: $775.76
I didn't need to get the front mounts, I bought them 2 years ago, but here is that info too:
20320PA011 <-Front Mounts $79.96each
Same part for both sides, you will need 2 ($159.92)
Old 05-05-2013, 11:54 AM
92 SVX 92 SVX is offline
So for the price you paid you could have bought the coil overs.
Old 05-05-2013, 11:58 AM
Old 05-05-2013, 12:21 PM
The AMR are $1500 and take 6months..
www.subaru-svx.net/forum/showthread.php?t=60228
Or you talking about the Taiwan ebay ones that take 4 months and had to be machined to fit and shipped missing parts..
www.subaru-svx.net/forum/showthread.php?t=58974
Subaru OEM took 5 days and cost $775.. Thanks for your input though...
Old 05-05-2013, 01:07 PM
Your sarcasm is duly noted, however I was talking about this thread
http://www.subaru-svx.net/forum/showthread.php?t=61487
yes they are the twain made set but after the correct dimensions were given he seems to have got it set up and in that thread I linked to the base price is about $800, shipping is $200 I think.
If what is written is to be believed 6 weeks is expected delivery.
Old 05-05-2013, 09:12 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Mike, how did PS pump work out for you.
1995 POLO LSI 76K MILES SOLD
Old 05-05-2013, 10:56 PM
Car goes in for the work today at 8am, I will let you know.
Yours seems to be in good shape, the bearings in mine are shot, the pulley on your used one spins smooth.
The timing on meeting you turned out perfect, by the time I got to the dealer in NJ the UPS guy was just unloading my parts.
By the time I got home from NJ, my kevlar/teflon rod end shipment from QS components was in my door waiting for me from my UPS guy.
Old 05-08-2013, 03:05 PM
I have a new front right tire, all 4 struts, front and rear strut mounts, engine mounts, used steering pump, and lightweight crank pulley, and QS component rod ends installed.
All that seem to be working fine, car is alined and everything is in spec now.
I had them chop the mounts and lower the PWR radiator to use the PWR cap because they had to pull it to do the crank pulley anyways...
Now the bad news..
They said they couldn't tell until they had everything else fixed, but now that all that is fixed and they got up above 50mph there is vibration in the steering wheel.
They decided it is the right front axle is shot..
So now far as suspension goes I have replaced the struts, mounts, ball joints, tie rod ends, and front swaybar end links, and now the right front axle..
Previous owner had the left one replaced in 2008, noticed it when going through the stacks of records that came with the car.
It is a good thing I love this car...
Anyone want to guess what will be broken next when they put in the new axle?
I gave the guy a new axle nut, his response was "ok, will use it if we need to".
I am hoping he meant if the axle he ordered doesn't come with one..
So the fun part:
New front mount next to the mount removed from my SVX:
Old engine mount:
Rear strut mounts were not as bad I expected, when I saw the fronts, I thought these would come off in pieces:
Old 05-08-2013, 04:31 PM
Looks like the rear mounts were replaced at some point. They're in good shape.
