Old 06-10-2008, 07:11 PM
mysvxrocks's Avatar
mysvxrocks mysvxrocks is offline
Im REALLY addicted! CANT STOP!
Send a message via MSN to mysvxrocks Send a message via Yahoo to mysvxrocks
Check Engine light question (Tranny Related??)
So my check engine light comes on when I start my car from a cold start, and its causing my tranny to not shift correctly. Ill floor it at like 20 and it seems like I am in 4th gear... the RPMs will go up correctly, but there is no power to the wheels. It will stay on for maybe 2-3 minutes on a cold start, then when it goes off, everything works correctly again, and the tranny shifts smooth. Anyone have any idea what it might be? I asked about checking it for codes, but the people at the auto store said it wouldn't show anything unless my CE light was on. Which it never is by the time I get to the store. Like I said, it only does this on a dead cold start, and does not come back on, even if I shut the car off and turn it back on again. Any ideas? Thanks -Dennis
D.J. McPhee
2006 Infra-Red Ford Focus ZX3 ~ 67k
No longer SVX'n, Ill always miss them!
1995 Polo Green LS-i ~ 95k
1992 Dark Teal LS-L ~ 145k (04/91) #2231
Old 06-10-2008, 07:20 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Is your engine temp gauge in the middle when this happens or is is dead at the bottom?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 06-10-2008, 07:21 PM
Can't see it being related to the tranny Dennis. Seems more like it is shifting back a gear, but the engine just dies.
You should be able to check the codes, following the 'How to", it will store the trouble code that was there.
Old 06-10-2008, 09:10 PM
mysvxrocks's Avatar
Its when its warming up. Its not in the middle, but its not at the bottom either.
Ill see if I can find that how to, and we'll see what happens. -Dennis
D.J. McPhee
Old 06-10-2008, 09:13 PM
Wikedjuggalo's Avatar
Rebuilding
Idk but mine has done this thing when its from a cold start if I don't baby it for the first mile or 2 it will shake really bad when idle and sometimes come off ; ;
Old 06-11-2008, 12:21 AM
mysvxrocks's Avatar
Exactly the same as mine. How long has yours been doing this? Any solution for yours?
D.J. McPhee
Old 06-11-2008, 12:36 AM
So what code did you get?
blk 92' LSL w/ average mods
Old 06-11-2008, 07:41 AM
Rebuilding
/hijack
Nope only happens if I don't let the car warm up from cold (over night parking) sometimes it does it other times it doesnt I'm not sure why but I'd love to know why and fix it anyone has an idea
Old 06-11-2008, 08:40 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Mine acted similar. Light went off after the temperature started going up and power came back to normal. Found stored code for knock sensor. Put in a new one and all is well.
Gene
Gene and Ben
Old 06-11-2008, 10:32 AM
Rebuilding
Gene
Thats next on my list I am sure that will help
Old 06-11-2008, 11:30 AM
bwb3's Avatar
Just remember there are 2 of them. The code will identify which is the offender if it is a knock sensor
Gene
Gene and Ben
Old 06-11-2008, 02:29 PM
mysvxrocks's Avatar
Am I doing something wrong here or what... every time that I try to go into the how to section, it NEVER shows anything there. It just says that there havent been any posts in the last 30 days. Then when I sort them from the start, only 4 show up........ What am I doing wrong here??
D.J. McPhee
Old 06-11-2008, 02:44 PM
bwb3's Avatar
Click on the "How-To Documents" at the top right of the page, then click "Electrical".
Gene
Gene and Ben
Old 06-11-2008, 08:31 PM
mysvxrocks's Avatar
Wow um..... ok.... here are the codes......
14 Fuel Injector No. 1 (Legacy, Impreza, Justy, SVX)
15 Fuel Injector No. 2 (Legacy, Impreza, Justy, SVX)
16 Fuel Injector No. 3 (Legacy, Impreza, Justy, SVX)
18 Fuel Injector No. 5 (SVX)
19 Fuel Injector No. 6 (SVX)
22 Knock Sensor or Circuit (Right Side on SVX)
Why is it throwing so many codes at me? What is wrong now
D.J. McPhee
Old 06-11-2008, 08:43 PM
There may be some old ones there. I would clear the memory, and see what it has the next time the light comes on.
