Old 06-06-2008, 04:31 PM
Bailey's Avatar
Bailey Bailey is offline
stalling issue unresolved by dealer so far
I took my car into the dealership yesterday for the intermittent stalling problem I have had the last few days and asked them to check the codes and focus on the MAF sensor or anything else they could find... (I posted previous thread about 3 days ago describing my stalling issue) This afternoon they told me they couldn't get the car to stall on them and it wasn't showing any codes. I faxed over to them the "how to" document from the forum on how to clean the MAF, they said they would look at it and perhaps try to clean it for me. I am frustrated that they were not able to find the problem. I am happy they aren't trying to sell me a part I don't need, but also afraid to drive the car much when it stalls.
any suggestions? I am not sure exactly what I am asking, but wouldnt a dirty or bad MAF code show up? Now I am wondering if it isn't the fuel.
Old 06-06-2008, 06:15 PM
Manarius's Avatar
Manarius Manarius is offline
Code wouldn't necessarily show up. I would try to replace it with a known working one. A MAF out of a Legacy will work as long as it's a JECS sensor from a 90-94 Legacy.
-Jason
-Obi Wan Kenobi
Old 06-06-2008, 07:26 PM
Bailey's Avatar
I appreciate your comment-I will find out what they say about the MAF when they get into it. From the symptoms, it sure sounds like MAF problem. I got the impression they hadn't gotten to my car until the end of the day today and hadn't spent much time on it. so I told them to relax since I dont plan to drive it until this is resolved. They said new MAF was around $300 or so. How likely is it that MAF needs replacing versus cleaning it? My car has around 100,000 miles on it.
Old 06-06-2008, 07:36 PM
Hondasucks's Avatar
Subaru Technician
There is an article on here about resoldering cracked joints in the MAF, that might be the problem (although those usually throw a code)
Another thing about codes, the computers in our cars are nowhere near as advanced as the newer cars, so a sensor that is bad, but still gives out a valid value, in most cases will not set a code. You might have a cracked vacuum hose or something, the PCV hoses in particular are known to harden and crack with age.
1986 VW Jetta
Old 06-06-2008, 08:16 PM
kwren's Avatar
kwren kwren is offline
stalling issue unresolved by dealer so far?
Why am I not surprised? they kept mine for 6 weeks and I ended up bring it home and repairing it myself.
Half the people on this form know more about a SVX than 90% of the Subaru dealers.
Sorry,
Keith
Old 06-06-2008, 09:45 PM
poweredx2 poweredx2 is offline
It sounds like your meter is bad,I just installed one in my car from a 96 legacy.I paid 20 dollars,no more cutting out at speed or stalling ,also replace or check your connector.
Old 06-07-2008, 12:19 AM
Hondasucks's Avatar
Subaru Technician
Sorry,
Keith
It all depends on the dealer, and how much experience the tech has that's looking at it lol
1986 VW Jetta
Old 06-07-2008, 11:36 AM
kwren's Avatar
Is true...
It also depends on what the problem is. Many problems are things that are routine but lack of experience on the SVX can be a problem for a lot of dealers, because the SVX is so rare. They just don't get any practice because there just wasn't that many sold.
Keith
Old 06-10-2008, 09:28 AM
Bailey
What the guys say above I agree with. It's most likely the MAF [it can be bad vacuum pipes and stuff, so you have to keep that in mind], but the MAF can suffer from a dirty element or from bad electronic connections in the square box. The first needs cleaning, the second needs dismantling and re-soldering.
I have used a Legacy turbo MAF myself with success. It is a straight bolt-in solution so long as it is the JECS type, and they are more plentiful than SVX mafs second-hand.
Don't completely condemn the techies for not replicating your problem; when I had the problem it manifested most often after a long fast drive, cutting out when braking for lights or junctions.
This might imply it needs a lot of heat build-up to replicate the condition, and the problem at the dealers is they will just give your car a little run from cold, and that may not show up the symptom.
Is there another SVX owner near you who could swap you a good MAF for a day? If it cures the stalling you will know immediately you need to fix or replace the MAF.
Old 06-11-2008, 09:07 AM
Bailey's Avatar
thanks for the information... unfortunately, no SVX owner near me to try a MAF swap for a day. The dealership service mgr left me a message yesterday that they had finally gotten the stalling to happen for them (they hadn't been able to get it to stall until yesterday- so your assessment is probably correct , that the car needs to be warmed up) but they hadn't found the problem yet. I still think it is MAF, I am hoping to hear something from them today. I would like them to try to clean it and re-solder but I wonder what they might charge for the labor for trying that or if they would be willing to try that.
Old 06-11-2008, 09:14 AM
... unfortunately, no SVX owner near me to try a MAF swap for a day...
Any Legacy owners that you know? A Legacy MAF will hurt you're high end power, but will work normally at normal driving. Good enough to let you know if that's the cause of the stumbling.
Old 06-11-2008, 09:25 AM
Well, that's gotta be the problem with living in Iowa I suppose; more chance of meeting a dead baseball player than another SVX owner.
If you get no joy from the dealer [they will probably want to fit a new expensive MAF first option], you have other possibilities. If you got the car back you could bolt the MAF off and either take it to an electronics shop or a computer shop and ask if they will repair it for you.
There is a How-To on here you could print off. The only thing you need to find would be the mastic for refitting the square lid to the MAF meter. It should not be too hard to do, so long as you find the right circuit board soldering person.
Old 06-11-2008, 10:41 AM
Talking about dealers!!
Guys you should all be lucky you live in the US and not in an arabian country.
Nissan sells cars here (Qatar) like crazy, and they do not even bother themselves into hiring certified mechanics to do jobs, nor even engineers for that matter.
All they do is hire very very low level workers, who never held a wrench in their life, and a foreman who has a catalogue of each part in a car and follows the instructions accordingly.
I dunno if I ever announced it to the board, but I am having issues with my Nissan gearbox, it is sticking on shifts... They changed the synchros and the problem got worse... I was able to diagnose the problem and I limited it to forks inside the GB, but never told them that...
I was debating that matter for the last 3 months asking for a NEW gearbox, and now I am getting it, will be installed in my car on Saturday...
You cannot just fix things around here, nor paint a car professionally... I am afraid now after my warranty expired... I might be obliged to send it home for specific serious jobs to be done
Just thought I would share these facts
Old 06-11-2008, 10:52 AM
You have a PM.
