4.44 question
What is the effect of a 4.44 swap on the top speed of the svx?
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
Technically the top speed using the 4eat is limited by the engine's lack of power, so there is no noticeable change in top speed, though it might top a little higher. Not sure how much. The 3.54 I think is 192 while the 4.44 is closer to 170.
So depending on how much power you are putting out, it will either increase or reduce your absolute top speed.
what is the difference in the cruising rpm's? Say at 70mph??
3000 RPM at 72 MPH with 4.44s with stock tires.
Eh instead of trying to answer all your questions by reading other threads, I figure I'll just link you this one.
http://www.subaru-svx.net/forum/show...=4.44+cruising
With 3.545; New stock tire height is 24.86", or 78.1" circumferance. or 811.2676 tire revolutions per mile. With a stock 3.545 ratio and full lock up that gives 2876.3087 driveshaft RPM or 1998.1582 engine RPM at 60 MPH. or 2395.3898 RPM at 72 MPH.
Does the Manual button(2nd shift starts)on the gear selector still work after a 4.44 swap?
1986 4WD Turbo XT coupe 5sp.(XTINCT) 1987 4WD Custom Turbo XT coupe (XTLUNAC) 1992 SVX LS-L (LUNACY) former: 1991 4wd XT6 5sp. (SUBDUED) Last edited by Alcyone Lunacy; 01-28-2007 at 03:56 PM. |
