Old 01-16-2007, 01:20 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Timing hole plug
Any ideas on how to keep this thing from falling off? Mine doesn't stay put.
Old 01-16-2007, 01:40 PM
My answer was to just leave it off....
Old 01-17-2007, 05:58 AM
michael's Avatar
michael michael is offline
What Potholes ???
If I knew where it was i'd offer some advise. Mabey a little silicone would do it and it cleans up well when you have to. I wouldn't want to drive around with any open holes given the messy winters up here. KY might not have constant road salt like we do
Wanted: Steering Wheel
Old 01-17-2007, 06:27 AM
We use salt down here....just that we hardly ever get any snow anymore
And the little hole it covers is open to the bellhousing, kind of under the throttle body on the passenger side....and the inside of the bell housing is open all the way across the bottom, so that little hole up top isn't really saving it from the elements....might even be good for rinsing it out....
Old 01-17-2007, 02:50 PM
Yes Huck it might also help with a bit of air cooling. I remember when converters had fins on the converter case, to air cool the ATF.
Old 01-17-2007, 03:25 PM
Harvey, you are still capable of hot air, but shy clear of standing up and being counted.
Old 06-15-2007, 02:51 PM
Replace it. The plug has little tabs to hold it in and have probably broken off line mine did. New one fits like a glove and doesn't come out.
Old 06-15-2007, 05:48 PM
dannmarr's Avatar
I work for my SVX
I took care of that with a little silicone.
Old 06-15-2007, 07:17 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
That's malarky Michael! My XT6 has been coverless for 30k and the belts look good as new. Plus the added benefit is you can actually replace them by the side of the road if need be without the hastle of a stinking cover. Besides, it looks so much better w/o 'em.
