Old 08-12-2010, 03:48 PM
angrygymnast angrygymnast is offline
Unhappy Mysterious Clanking Sound
I just purchased a 1992 SVX and the car runs great. However, whenever i drive over a dip or a bump the car makes this strange clanking/jingling sound that appears to be originating from the right side of the car. The noise sounds like a chain rattling or something of that nature. If anybody has any idea of what could be causing the sound it would be greatly appreciated.
Old 08-12-2010, 05:50 PM
Blacky Blacky is online now
Re: Mysterious Clanking Sound
Check your sway bar end links. When I bought my black one it made the same sound and it was the right front end link completely disconnected that was making the noise.
Try holding your foot lightly on the brake while it's doing it, if it stops, it's worn pins and sliders on your brake calipers.
Old 08-13-2010, 10:34 AM
How "solid" is the sound. If it's a very light rattling/clanking, it could even be heat shields that have started to rust away.
Old 08-13-2010, 11:51 PM
Checked the sway bars and the heat shields. All are good. It seems to be coming from the top of the strut; the gold-colored thing at the top of the shock... If you hit it with the dust shield, it seems to make the noise... Anything up there that could make this noise?
Old 08-21-2010, 08:51 AM
Naru's Avatar
Naru Naru is offline
did you have check the bearing in the center of the main axle ? ( carrier bearing? )
i have some strange sound to, and i have find this bearing doing it.
plus, the main axle move and lightly touch the heatshield below of it.
so that make somes "clanks" and "tching-tching" sounds!
Old 08-21-2010, 09:17 PM
BRADY's Avatar
BRADY BRADY is offline
SVX Addict
Send a message via MSN to BRADY Send a message via Skype™ to BRADY
I have almost the exact problem. I am going to take the front wheels off and take a good look. The noises I am hearing are coming from my left front calliper and and shock tower.
The worn pins and sliders Blacky mentioned sounds like it could be a major cause as when I depress the brakes, the sound settles down. Thanks!
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com
Old 08-21-2010, 09:23 PM
I too have been having this problem recently. I had Subaru look at it and they were unable to determine the source of the noise with the car in the air, so it must be a worn moving part.
Old 08-22-2010, 06:31 AM
immortal_suby's Avatar
Thread Killah
I'm getting a pretty solid clicking on hard left turns under power that I can feel through the gas pedal. Replaced both halfshafts. They were shot anyway.
Still there.
Waiting on the ball joints to show up and those are next.
But I checked my caliper and it also will wobble around like you mentioned. I'll have to take the same turn with the left foot on the brake and see what happens.
Locker Link
2015 BRZ Limited 6MT
Old 08-22-2010, 01:00 PM
kwren's Avatar
kwren kwren is offline
brake caliper can clank...
Keith
Old 08-22-2010, 04:55 PM
processengr's Avatar
Still there.
FYI:I got a clicking noise from the front when on washboard surfaces. No amount of "bouncing" the car statically could reproduce.Ended up replacing front strut upper mounts/bearing assembly. Fixed. I have done this now on two different '92. YMMV
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
