Going price for my 95 svx L awd?
Hi all, i'm in the process of trying to figure out what to do with my svx that i bought. Originally i bought it for its drivetrain for my legacy, but it's going to take more work than it's worth to convert it.
It's a 95 svx L with awd. WRX blue color with only 61k miles on the clock with new rotors and recent 60k service. It will come with a reconstructed title after it's repaired. The damage is a bent frame, pushed up about two inches-head light-side marker-air bags. The rest of the car is mint! I plan on fixing the damage before i sell it. So what would you guys be willing to pay for this car provided the repairs were done professionally (minus the airbags) and everything look/worked as new? Thanks Brent |
Value of a 95 SVX L AWD
Assuming it has frame damage and that it is properly fixed (you'd still have an announcement of frame dmg at an auction) anywhere from 3-5 grand depending on all the other variables. Why do all the Laguna's have to be so far away???
i'm paying 5000 for a 95 L awd, and it doens't have frame damage, or any drivetrain problems, it's got paint problems... and trim problems...
so i don't know what you might get for one w/ frame damage
SV What? |
Re: Value of a 95 SVX L AWD
I wonder why yours is like that. Mine has absolutely no rust to speak of anywhere, and ive never had any problems with even slightly rusted bolts. Weird.
Mike |
That still wouldnt make much sense... my car has been used year 'round with the acception of this winter since it was new... it, in theory, should be just as bad.
Mike |
Salt is corrosive and needs to be washed off. When it is not washed off, often in the winter when salt is used, it will cause the rust. I have been getting my car washed every week this winter. Last year it was no big deal as there wasn't that much salt being used. The top of the rear strut mounts are a definate needs to be flush zone. Those U spray yourself places are the best way to get the bottom side flushed out.
Re: Re: Value of a 95 SVX L AWD
You coming to reading? |
Re: Re: Re: Value of a 95 SVX L AWD
I'd like to go to Reading, but its too far too justify. I'd be putting 6k miles on my car for one weekend of fun.
Re: Going price for my 95 svx L awd?
In the state on Montana it goes from salvage to reconstructed once the repair work has been completed and you get it inspected.
If you don't get it repaired/inspected the title stays salvage and can't be licensed i believe. If i can't get the frame straight then i know of a certain parts car that will be getting cut up for the proper pieces. Brent |
