Old 06-05-2015, 09:39 AM
Brian's Avatar
Brian Brian is offline
WTB: A/C pressure switch
I'm looking for an A/C pressure switch. It's on the right (passenger) side of the engine compartment, right next to the radiator and condenser. It's connected to a block-shaped juncture on the metal A/C line running from the top of the receiver-drier to the bottom of the condenser. It's not shown on the diagram I looked up on the current version of SubaruParts.com. It did show up on the dealer's part department's system, but without it's own part number, just a "reference number".
Old 06-08-2015, 10:00 AM
Brian's Avatar
Re: WTB: A/C pressure switch
Here is a low-res diagram with the Trinary Pressure Switch colored yellow and circled in red.
Old 06-08-2015, 12:18 PM
processengr's Avatar
This switch is only available attached to the pipe, as part of an assembly.
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 06-08-2015, 01:26 PM
Brian's Avatar
Yeah. Actually I already knew that was the case from Subaru itself, but If someone is selling from a parts car or random parts they've collected, they could potentially sell it separately.
Old 06-10-2015, 03:33 AM
I have one but there is no way to separate the switch other than cutting the pipe somewhere. The rubber pipe is damaged on it.
Old 06-10-2015, 08:31 AM
Brian's Avatar
I think you might have the wrong switch in mind. There are no rubber pipes connected to the switch I'm looking for, just metal (aluminum) pipes. If you check out the diagram I linked to above, you may be able to tell if we're talking about the same thing. At the point where the switch connects to the metal block-shaped juncture of pipes there's a bolt type of ring that looks like it would accept a wrench. Looking straight down at it, there's an electrical connector facing up.
Old 06-17-2015, 05:32 PM
I found what you're looking for. I'll see if I can get it apart undamaged and I'll let you know.
Old 06-18-2015, 07:46 AM
Brian's Avatar
Thanks, Blacky! I appreciate it, but I'm already waiting for one to arrive that another member has sent. If I run into a problem with that one, I'll let you know. I wouldn't bother trying to separate it now. I do anticipate one possible problem: I don't know what kind/size of O-ring gasket I'll need for where the switch connects to the pipe juncture, or if and where I can get a suitable substitute.
