  #91
Old 12-31-2009, 06:30 AM
Seraphinwolf's Avatar
Seraphinwolf Seraphinwolf is offline
H6 THE ONLY WAY!
Send a message via AIM to Seraphinwolf Send a message via Yahoo to Seraphinwolf
Re: Twin Turbo EG33 Build - cozykat
twiddles thumbs waiting for next update...
I got a TD04 for free last month and can get a few more cheap currently and with soon picking up a MS2 for the SVX I'm getting that itch and it's all your fault Marisa!
On the intercooling note. I"ve seen a couple pipedream drawings on the wall at Synaptic3 using RX7 OEM intercoolers and using them as part of new manifolds. The two main guys over there are secrect SVX nuts and their mother is on her third SVX. (Sweet old lady about 5' tall... maybe 80lbs! LOL)
On the FMIC note I would think a long skiny core up front with do the trick just fine. Plus just adding in a hood scoop just in place to run fresh air over the engine and cool the engine bay will provide all the cooling you need. Along with a nice say PRW radiator. Seriously this radiator rocks! I actually have to NOT turn on the heat in the car till the engine warms up cause it cools so efficently in the winter. Even to the point that if I set the fan too high it cools too much and I get blasted with cool air...
94 Bordeux Pearl LSi (Jun 2009) 109k Plate:GADDIS
What they call it a vanity-plate. Shouldn't I be obligated to be vane with it?
Rota Tarmac 3's 18x8" on 245/40/18 Dunlop SP Sport 600's, Perrin light weight crank pulley, PRW radiator, custom coilovers(not GC's), 9006 HID 4300k 50W low beams, DIY garage door lip, and SVXfiles brake kit. Fixxed exhaust so no more sweet sound.
97 White/Black trim Impreza Outback Sport (March 13/08) 150K-180K(sensor broken)Good news is EZ30R and 05' 6speed full powertrain swap is in motion!: Will be doing more work as I can. Gonna be run by a Hydra so yeah fun to be had.
[SIGPIC][/SIGPIC]
-Gaddis
Old 08-16-2010, 10:56 AM
cozykat's Avatar
cozykat cozykat is offline
Still rebuilding my block...
Alcyone Silver Contributor
Okay.. so I am terrible at updating. Well really, there wasn't much to update on.
I decided to purchase Mike's 244 duration intake camshafts with the 264 duration exhaust camshafts since they seemed like a good option. From order to delivery it took about 2 months (I think) due to it being a custom job. Mike has to acquire cams first since I opted to keep my stock cams. I consider installing my stock cams and dynoing and then swapping to compare results. However, I kinda just want my engine together already.
good news: started assembling my block. A coworker who is a veteran mechanical engineer offered his workshop and guidance. His job is building/rebuilding engines while testing the effectiveness of oil lubricants. Considering it is my first engine build from the ground up, I've been hesitant to simply start slapping things together. While I can follow directions, I lack the experience to have developed techniques and tricks to ensure a successful build. So its been a great opportunity for me to learn good techniques.
The short block is assembled and its starting to look like a long block:
Marisa
Old 08-16-2010, 11:02 AM
NeedForSpeed NeedForSpeed is offline
Hi Marisa,
Nice pics, it looks like you are making great progress
Keep the pictures and news coming
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 08-16-2010, 01:56 PM
cozykat's Avatar
Thanks This will probably be one of the slowest builds EVER!
Side note: As Shaun (yourconfused) mentioned way earlier.. I like the idea of a FMIC.. the alternative would be air to water intercooled. I am still struggling with my final decision and probably will until I simply purchase one or the other.
I don't think I posted up pictures when I played with the Perrin FMIC (purchased for the STI) and the bumper I got from Dayle:
Marisa
Old 08-16-2010, 06:01 PM
sd2649's Avatar
sd2649 sd2649 is offline
Driving in Style
Looks very nice! I plan on dropping the engine out of my parts car sometime this year. It runs well but has 160k on it.. i don't plan on such a nice rebuild, just a very stockish overhaul one of these days.. i would love to see that in pieces, looks like fun!
-Steven
1992 SVX Purple and Black 5 speed swap
SOLD
*1993 SVX Silver and Black
*1994 SVX L Barcelona Red FWD
Old 08-16-2010, 06:53 PM
Cam Cam is offline
Looks extremely nice. How long will you wait before you introduce forced induction?
By the way, I like your dial torque wrench.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 08-16-2010, 09:29 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
Smile Re: Twin Turbo EG33 Build - cozykat
It will fit but you will need a torch to cut the bumper beam. The cover is not the issue. Not bad though I have a 18x9x3 core behind a stock bumper.
Clean project and I look forward to the finished project!
~Phil
Old 08-17-2010, 08:37 AM
cozykat's Avatar
Yeah, in the STI we had to remove the bumper beam altogether. I don't want to do that in the SVX but I don't want to hack anything either. I need to see what the dimensions are for the Mini FMICs. Maybe they are narrower but just as long... Again, I may just go air to water but it was cool to see as far as the bumper was concerned, the opening was just about a perfect match to the intercooler.
Marisa
Old 08-20-2010, 05:38 AM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
Your catching up to me... I need to get my rear in gear haha
Good progress!
Old 08-23-2010, 11:58 AM
Banned
Most companies sell a replacement bumper support beam with their FMIC kits I'd like to get the dimensions of the perrin one and see if it will bolt up to our front end with little to no modification. will check into it.
Old 10-13-2010, 08:15 PM
sd2649's Avatar
Driving in Style
Any more progress? Where is this being built in SA?
-Steven
SOLD
Old 10-19-2010, 12:59 PM
cozykat's Avatar
In my garage. And yes some progress made, but I'm slow. I was supposed to have everything sealed up this weekend but got side tracked. Breaking down and ordering wiring harness.. Having exhaust and intake manifold coated but I'm fighting myself about the iris and if I should just remove it.
Marisa
Old 10-19-2010, 03:27 PM
I would keep it, as it will still provide the torque between 2000 to 4000, that may be lacking with the turbo. Every little bit helps.
Old 10-19-2010, 07:06 PM
Phast SVX's Avatar
FWIW I have kept mine with no issues.
~Phil
Old 10-19-2010, 08:04 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Mine seems to have disappeared!
The same, there's a reason the thing's there: It's a performance part. Naturally, by adding some turbo action, it either helps the same, is just in the way, or... could be tweaked? Is it possible that it might give you some sort of performance benefit by being activated at a key RPM that may be different than when it is now?
IIRC, it's closed in the lower RPM range. I'd consider keeping it for the off-boost moments?
