#121
Cool, keep us posted
#122
Factory Cam Specs
Okay, I'm not sure at what amount of lift the durations are measured at...figured it was a nice piece of info to add to this thread
-Bill and a little info to see if we can use anyone else's valve springs...
Retired NASA Rocket Scientist Most famous NASA "Child" - OSIRIS-REx delivered samples from asteroid BENNU to Earth in Sept. 2023 Center Network Member #989 '92 Fully caged, 5 speed, waiting for its fully built EG33 '92 "Test Mule", 4:44 Auto, JDM 4:44 Rear Diff with Mech LSD, Tuned headers, Full one-off suspension '92(?) Laguna, 6 spd and other stuff (still at OT's place) My Locker Last edited by SVXRide; 09-06-2006 at 02:39 PM. |
#123
Cam. specs.
There is a lot of good info there Bill. Take a bit of time to go through them all, see what there is and what Delta can match up with. They look like they are all 4 valve engines, with some hyd, and some solids.
I think the duration is at 0.006". The same as the 240* that the WSM quotes for the eg33. Harvey.
#124
I'm trying to walk the fine line with Scott of keeping this effort in his frontal lobe, yet not being a "pest" It appears that the cores that he thought were VG30DEs weren't, so he said he's going to look around some more to see if he can find another set. As I'm feeling a little lazy right now, do you have the lobe center degree spec for our stock intake and exhaust cams? -Bill p.s. is your computer program set up to do trades on intake runner length? I can do the runner area vs torque peak rpm trade now, but I'll run out of aluminum before I get much above the current ~4800 rpm.
#125
The lobe centers are Inlet 114* ATDC, Exhaust 113* BTDC. This is from the timing figures, the actually figures have not been measured, so if the opening and closing ramps are not symmetrical, the lobe centers would be different. What do you mean? do you want to shorten the inlet tracts to raise the peak torque rpms.? Harvey.
#126
Update
Well, I just got off the phone with Scott (again) and the guy that promised to send over VG30DE cores still hasn't, so Scott promised to get on the phone to him today to "nudge" him about it. As my current 193k+ engine is starting to show its age, I'm definitely ready to get into the "spare" engine in the garage
-Bill
#127
http://www.geocities.com/pepesvx/e3.html
Harvey, The info sheet found above lists different opening and closing ramps for the cam lobes. Quote:
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
#128
I would still like to see it measured to be sure. Harvey.
#129
Update -- 11/6/2006
Okay, spoke with Scott at the end of last week and he's having no luck with VG30DE cores - last one he got was - again - the wrong cam. Good news is that I just bought two VG30DE heads with cams! I'll be shipping the cams to Scott as soon as they show up.
-Bill (loving it when a plan comes together )
#130
I don't quite understand are we goin for top end power or low end, I think the car excels at 4-7rpm. So I would rather have cam lobes that meet that catorgy, is that what you have in mind? I don't mind being a little slower off the line as long as I fly at top end. lol
-Chris '94 ebony pearl, with orange "silicone" hoses, painted beauty cover, Tom's Intake, Dayles Cold air intake; with HKS mega suction foam air filter, 3in header back exhaust, STI ground wires, euro front fascia, euro front grill, reactive 17in wheels, Nitto Invo's, Drilled and slotted rotors, stainless break lines, Koni strut inserts, Drop springs, 5MT, shotshifter, Clutchmasters clutch, ACT prolite flywheel, EL Glow gauges, The ECUTune stage 2. To Do: Cams, port and polish, etc. |
#131
Bill, since you have the head as well, take a look at the valve train... See if we could adopt their springs and valves for our own
Tom |
#132
Are they solids?
#133
Danny, Nope! -Bill
#134
Bill,
Did Scott measure the cams? Quote:
#135
Matt,
Now that you made the Rally, can you tell us what cams, valves, springs, etc. you finally used? Quote:
