Old 02-03-2011, 07:42 AM
Bonestock's Avatar
Bonestock Bonestock is offline
Nürburgring Warrior!
Thumbs up Gene's DIY CAI thread
Hey guys, while Gene aka 92 SVX was over working on his interior wrap project I spotted a very nice and cost effective mod he had made to his car. A low cost cold air intake (CAI) made from off the shelf parts found at your local parts store. I believe the total cost is around $75??
I have now dubbed his intake the "GDIY" (pronounced Gee-dee) mod I am hoping I can encourage him to do up a "how too" with at least the part numbers needed to copy his work....
Here ya go Gene.. your very own mod. You deserve it because its simple, cost effective and a classic case of hot rodder ingenuity.
C'mon Gene!
2010 Subaru WRX
1992 SVX LS-L 89k miles-SOLD!
KTM 250sx MX bike aka "Killer Pumpkin"
Old 02-03-2011, 08:57 AM
92 SVX 92 SVX is offline
Re: Gene's DIY CAI thread
I have now dubbed his intake the "GDIYCAI" (pronounced gid-dy cah-eye) I am hoping I can encourage him to do up a "how too" with at least the part numbers needed to copy his work. OK, the name might need some work...
C'mon Gene!
Thank you, ok I will attempt to explain it though Im better at doing then explaining.
Old 02-03-2011, 10:31 AM
Ok Here it goes.
First I started by cutting out the Accordion section of the stock tube, for 2 reasons first it allows lots of movement, and second using smooth walled tubing should help air flow.
I cut it as close to the idle control nipple as I could and still put a silicon coupler on you can cut it with a hacksaw. I think I used tin snips. I used a 3" silicon coupler from oreilly's. Part # 8771
$7.99 needs 3 for my setup. I also needed to heat it up just a little to open enough to go on.
Then into that goes a 22 degree bend part #8728
at $11.99. This will connect to a 4" straight piece part #8708 using the clamps that come with all these pieces $8.99
Which then connects to a 45 degree bend
Part #8738 $11.99. Using the second of the silicon couplers this attaches to the stock MAF again needing some heat to fit. Then maf adapter part number #81413 $13.99
Discarding the plastic piece as it is for a smaller diameter piping. You will need to line up the inside and drill new holes to fit your maf.
Then the maf adapter couples to the 90 degree bend part #8698 $10.99
Then that attaches to a 6" straight part #8718 $9.99
Then put your filter on the end. I had a filter so that was not included in the price but if you need one part #8136
cost $24.99
With out the filter it was $91.99 A little higher then my initial estimate.
That is what I did as I pieced them one at a time if you want you can get the short ram part # 8208 for $39.99
comes with one coupler and 2 4" and the 45 bend which means you would only need the 22 bend the 90 and 2 couplers. You do need a straight piece inside the fender but the 4" may be enough I had the 6" so that is what I used.
Using the Short Ram without filter its $78.95
Old 02-03-2011, 10:40 AM
I also went and did the crank case breather mod.
Old 02-03-2011, 11:21 AM
Bonestock's Avatar
Nice, great write up Gene!
2010 Subaru WRX
Old 02-03-2011, 03:26 PM
Bonestock's Avatar
I wonder if this is a direct fit to our stock MAF?
2010 Subaru WRX
Old 07-08-2012, 03:21 AM
steveherman steveherman is offline
Originally Posted by 92 SVX View Post
Ok Here it goes.
cost $24.99
All the pictures are gone.
Kinda makes this thread less helpful.
Old 07-22-2013, 12:25 PM
NineBreaker NineBreaker is offline
Bump on these pictures.
I have an understanding. just would like to see what has been done.
Old 07-22-2013, 02:20 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Just a little searchy with the part numbers gives these goods:
http://www.summitracing.com/parts/spe-8771
http://www.summitracing.com/parts/spe-8728
http://www.summitracing.com/parts/spe-8738
http://www.summitracing.com/parts/spe-81413
http://www.summitracing.com/parts/spe-8698
http://www.summitracing.com/parts/spe-8718
http://www.summitracing.com/parts/spe-8136
http://www.summitracing.com/parts/spe-8208
Probly looks a good share like this when done:
http://s17.photobucket.com/user/BVM0...11723.jpg.html
I'll let you do the rest.
