factory ignitor(s)?
Does anyone know how many ignitors there our in the SVX ignition system? Is it a single ignitor, or are there multiple ignitors (e.g. one for each coil)?
Thanks,
Re: factory ignitor(s)?
ok. Thanks. :-)
Re: Re: factory ignitor(s)?
Re: Re: Re: factory ignitor(s)?
Re: Re: Re: Re: factory ignitor(s)?
Any way yes you could run three double coils. When we did my sons Datsun, the head we fitted used 6 coil on plugs. We changed to a GM ECU and ran three double fires. No problems but that did not have an auto that shuts down every second firing to ease the selection of gears when the idle is fast. Harvey. As an after thought, the ECU has 6 trigger wires going to the ignitor block, you could tie 1&2, 3&4. and 5&6 trigger wires together with diodes and trigger the pair together. Still use the 6 coils on the plugs.
One Arm Bloke. Tell it like it is! 95 Lsi. Bordeaux Pearl, Aust. RHD.149,000Kls Subaru BBS wheels. 97 Liberty GX Auto sedan. 320,000Kls. 04 Liberty 30R Auto Premium. 92.000kls. Last edited by oab_au; 01-22-2004 at 06:30 PM. |
My plan was to use only 3 of the coil drivers on the aftermarket ecu and retain the use of the factory ignitor block and factory coils.
Thanks. So the diodes will face towards the ecu outputs?
The trigger wires on ignitors 1&2 have the diodes anoid connected to them and the two cathoides are .connected together and connected to the ECU trigger. Harvey.
lol. I'm pathetic. I don't know those terms. I do understand that the diodes are added between the split and the ignitors, but I don't know which way to align the diodes. Will the current be limited to flow away from or towards the ecu?
