Old 07-01-2011, 05:36 PM
Crank pulley keyway damage
I'm looking at buying a 1st gen legacy wagon, and wondering if there's any way to properly/safely repair a keyway from the crank pulley coming loose and damaging the keyway. In the ad, the person says it would need a replacement shortblock or at least the crank replaced. Just wonder if anyone knows of anyway to make a repair and have it last?
Thanks in advance
Old 07-01-2011, 05:53 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Re: Crank pulley keyway damage
Thanks in advance
Can haz welder then while your at it change the oil and weld the hood shut.
Old 07-01-2011, 09:06 PM
hahaha, I'd be looking at keeping it for awhile, probably as a winter car.
Old 07-02-2011, 05:25 AM
michael's Avatar
michael michael is offline
What Potholes ???
It depends on how much damage is done. You can get a new key and either loctite it in or weld it in. If the engine is on it's last leg you could just weld the pulley on
Wanted: Steering Wheel
Old 07-02-2011, 12:18 PM
Did that on my 56 Chevy. Just a spot weld . Poor guy that got it after me ruined his wheel puller trying to get it off to change the timing chain. All u do is grind the small weld bead with a dremel tool
