Speed sensor(#2) Q's
I am attempting to test my speed sensor for the correct signal but am unsure of what the readings are supposed to be.
After a search I found that the reading on the y/r signal wire should be between 0v and 5v while slowly turning a front tire. However, the k-sensor range chart states: ECU Connector Application Pin No. Wire Color Justy Carbureted .......... 6 (22-Pin) ................ LT GRN/BLK Justy PFI .... ............. 4 (22-Pin) ................ LT GRN/BLK Legacy .................... 11 (12-Pin) .................. GRN/BLK Loyale .................... 22 (24-Pin) .................. YEL/GRN SVX ....................... 11 (12-Pin) .................. YEL/RED (1) - Turn ignition on. Connect voltmeter between indicated terminal and ground. Slowly rotate drive wheels. Voltage should fluctuate between zero and about 5 volts (Legacy) or 2 volts (except Legacy). So I should expect the voltage to be between 0-2 and not 0-5? Also, are there supposed to be any wires that splice into the speed sensor signal before it gets to the ecu? I have 2 wires that splice into my speed sensor signal about 4" from the sensor connector. I am unsure what they are for, don't think they belong, and they could be messing up the voltage. |
