Engine miss and 99 outback
Hi, recently my 94 SVX has developed an infrequent miss while sitting at a light. Like one cylinder didn't fire then runs fine for 5-10 seconds and will maybe do it again. Not every light just once in a while.
Friend totaled a 99 Legacy outback automatic AWD. I'm thinking the 4.44 is the gears in this but all references I've seen only go up to using 98 trans and diff. What's different or can the 99 be used? Thanks, Don |
Re: Engine miss and 99 outback
If it is a '99 with the SOHC engine it won't work. They changed over to the new engine and tranny in '99 and it's not easily compatible.
Could be the coils? I had similar issues and when I replaced mine (with better condition used ones) the problem disappeared.
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
The outback is a turbo and I'm not sure but that might be a 2.5.
I'm sure I could find some used ones and if that took care of the problem that would be only OK as I'd have 6 coils and not know which one(s) are bad. I hate to fix what isn't broke.
measure the primary coil resistance. If the resistance is extremely low, this indicates the presence of a short-circuit Specified resistance: [Primary side] 0.68 - 0.83 Ohm So check your coils and see which one could be bad. Its a free somewhat easy check. I would grab the manual as it explains how exactly to check the coil.
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R Last edited by theflystyle; 03-13-2015 at 06:52 PM. |
Thanks flystyle, after I'd posted I looked in the manual and found that information. I keep forgetting I have the manual. Also sometimes there are other ways to check things that people have learned that aren't in the book and easier. I'll start there but concerned that since it is so infrequent it might not show up with the ohmmeter.
Don |
I had a misfire which only showed up when the engine was hot and under load such as climbing a hill. It was one bad coil.
If you unplug one at a time you can easily find the bad one. If you unplug a good one the car will run worse. If you unplug a bad one the car will run the same. |
Thanks Blacky. The miss is VERY infrequent so getting to duplicate the conditions is difficult. Seems I'd have to drive with a coil disconnected, running on 5 cylinders and see if while sitting at a light I get a miss. After a few days change which is disconnected and drive like that again until I never get a miss. When I had a coil go bad I disconnected an injector to find the bad coil. Seems it would be easier on the car to drive with an injector disconnected as I'd not be putting fuel into a cylinder that may not fire infrequently. Testing the coils electrically as described in the manual seems the way to go at this time.
