Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Suspension
Old 10-12-2013, 02:41 PM
david_12121's Avatar
david_12121 david_12121 is offline
The NEWBIE
Lowering Springs
I just installed some Enkei 18X8.5's with 225's for now, which has very close outer diameter compared to stock. A little lighter though.
So it's all good except that the wheel gap is very noticeable, especially with the low profile tire.
I really want some coilovers but all my money is going into a V8 RX7 project I have. (For those who remember my plan to put an LS1 in the SVX, I decided to first do one to an RX7 and do the SVX next year)
I've been looking to find some for the SVX but failed, so is there any other car's that is compatible or do I need to get one custom made?
What I want out of it is about 2" lower in the back and about 3" on the front, but anywhere close to those will be fine. I also need it to be very stiff as I don't really care much for comfort as I haven't been spoiled with it over the past.
Thank you guys in advance.
DIY FTW!
1993 SVX 25th Anniversary Edition @+142k
-Rebuilt Tranny @135k
-Regasketed Engine @140k
-Enkei Raijin 18x8.5, with 255/35/18's @140k
-BC racing Coilovers (From STI's) @142k
Old 10-12-2013, 10:52 PM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
Re: Lowering Springs
v8 swap has already been done
Old 10-14-2013, 12:31 AM
The NEWBIE
I know...He had a carbed one though, and he's either done or in the process of swaping that for a whatever's-in-the-300zx.
Someone else was doing a full corvette swap with the transaxle and everything but pretty sure it'll take him a while.
Regardless, how can I go lower? For cheap...
Edit: Lower AND STIFFER
DIY FTW!
Old 10-14-2013, 09:37 PM
INVADR's Avatar
INVADR INVADR is offline
Pew Pew!
AMR and Ceika are two options. $1500 and $800, respectively. There's Aragosta, too, but they're about $3500.
Some folks have retrofit coilovers from 05-07 STi onto our cars. Takes some work, but isn't horribly difficult.
Search the boards. The information is not hard to find.
Mark S.
1995 LSi, EPM, #1152, 197k(ish) miles, 5-speed
Old 10-15-2013, 05:21 PM
Coan's Avatar
Coan Coan is offline
Alleged User
Here's a good thread on the 05-07 STI coilovers. This opens up a lot of options as there are many aftermarket coilovers made for STIs.
Jon
1997 SVX LSi Bordeaux Pearl
1995 SVX L AWD Polo Green - 277k miles
1986 Pontiac Fiero 3.4L Twin Dual Cam V6
Old 10-15-2013, 08:32 PM
stiguy's Avatar
stiguy stiguy is offline
Don't cut them I tried that few weeks ago. It looked good but creaked and pulled to the left a lot due to the cut springs. What I'm going to do it is buy spring clamps then weld the coil together that is touching. It will lower it 1.5-2"
#1 1994 Ls ebony parts car-rip
#2 1994 L laguna blue - sold
#3 1992 Lsi pearl white - sold
#4 1992 Lsi pearl white -Ate two engines - Rip
#5 1994 L Laguna Blue fwd - Now Awd and manual - 03 wrx 5mt - 18's stern warp st4s - totaled hit a tree
#6 1992 Lsi custom orange parts car
#7 1992 Lsi green 4.44 swap. Currently for sale
#8 1992 Lsi custom pearl white. Project car... sold
#9 1992 Teal 4.44 swapped... sold
#10 1995 Laguna Blue. Sti 19 wheels,
#11 1994 Laguna Blue. Came with #10 engine and trans are out but plan to put it back on the road. Willing to sell it at any time! 😂
Old 10-15-2013, 08:48 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
If you want cheap, low, and stiff, go buy raceland's 05-07 STi coils. 450lbs/in front and 280lbs/in rear. From what you've told us, you're more than capable of doing it yourself $500 and some elbow grease. Go read my thread and let me know if you need any help
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 10-15-2013, 11:23 PM
The NEWBIE
I already knew about the STI ones, did my research. Even found some used ones, one being Stance branded, for 600 but I prefer to go the lowering spring route first. $2-300 and the same result for my intended function.
I don't really drive it hard enough to need the adjustable dampening nor the preload and all of that. I don't really drive the SVX hard enough...that's my RX7's job with its awesome Megan Coils.
Just need a bit low and as stiff as possible.
So I guess that's a no on other compatible cars? Anyone know of a place that custom make them?
Regadring the cutting, no, never. It'll be lower but so soft it will rub constantly.
DIY FTW!
Old 10-17-2013, 01:07 AM
B 4 You's Avatar
#lolsvx
The only lowering springs (that I know of existing) are Dayles at Planetsvx.com, but they have a very similar spring rate to stock, so you won't be getting a stiff ride.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 10-17-2013, 02:29 AM
The NEWBIE
Thanks. Then I might do the coilovers you recommended. Or some other, depending on what I find for cheap.
Also, can I ask how much camber you're getting? How much lower? Have camber plates?
DIY FTW!
Old 10-17-2013, 03:21 PM
B 4 You's Avatar
#lolsvx
I think Racelands are the cheapest you'll find new, but I'd definitely check your local forums and see if there are any used coils around. As far as camber, the racelands have plates in the front but solid mounts in the rear. The fronts are at 0 degrees, and the back are at 0 degrees. The front is probably 3" lower, and the rear is probably 1.5-2" lower. You will need camber bolts to the your wheels in spec if you plan on raising it any higher than mine. The only reason my camber is in check is because of how low it is, but you already said you want it low so that shouldn't be an issue. I also had no problems getting the car 100% aligned into spec
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 10-17-2013, 04:49 PM
The NEWBIE
That's amazing, man. An no rubbing? I have 8.5's and although I'm trying to run 245/35/18, I might have to run 245/40/18. The 35 will be slightly smaller than yours and stock but the 40 would be quite large at 25.7 compared to the 24.8 stock , so I might have to be higher than you. It all depends.
I'll definitely check that out.
DIY FTW!
Old 10-17-2013, 09:19 PM
Tapani Tapani is offline
I think the springs from Dayle have app 50% more spring rate (than stock). I installed a set this summer and they made a huge difference compared to stock. Personally I would not go any stiffer in a daily driver - but of course this a personal matter . So far I've only been to a track day once, but the difference is very noticeable - it doesn't feel quite the barge it used to . Nice to see how they behave when the snow comes...... softer is usually better on ice tracks.
I run 245/45-17 summer tires on STi wheels and 215/60-16 winter tires (studded Nokian Hakka 7) on stock wheels. So far no rubs with either.
/T
Old 10-17-2013, 11:58 PM
B 4 You's Avatar
#lolsvx
I have no rubbing at al while driving. I just raised the left front side a third of an inch due to rubbing in steep driveways, but other than that, nope! And I'm running just stock 225/45/17 on STi wheels, but I'm pretty sure you could easily get 245's in there. It all depends on your wheel offset. And, if you add a bit of camber, you can get a lot more aggressive. I just wanted it close to stock for every day driving. I don't like buying tires. Also, a stiffer spring rate will give you less travel, meaning less rubbing. If I was this low on stock suspension... it would be a nightmare.
Also, in my previous post I meant to say that you will need bolts for the rear if it will be higher than mine. The fronts won't need bolts if you have plates, but even then I have them set to 0 on mine.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 10-18-2013, 12:54 PM
The NEWBIE
Just took a look at the lowering springs on planetsvx...they don't have enough low for me. Not only that, but the price is so high for what you get. I prefer to pay a bit more and just get the coilovers.
Regarding my offset, they're +35, but I'll be running around +20 of spacing on the front and maybe +30 on the back. Might have to roll the fenders and remove some of the plastic covers underneath.
And for harshness, I often drive an extremely lowered Lexus (the most preload possible), a lowered and almost no travel RX7, and a supersport motorcycle for my daily driver. I fortunately/unfortunately am not spoiled with the gift of comfort so I'll be okay.
This is what happens when you become best friends with a "hella flush" person...you start to become like them!!!
Thanks guys...Y'all have been very helpful
DIY FTW!
