Old 07-12-2011, 10:22 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Best fuel pump without modification?
I browsed RockAuto to see what choices on fuel pumps and I would like one that requires no modification.
I see Beck/Arnley, Airtex, Carter, and Delphi...any good choices there?
Same question with fuel pressure regulators...I would assume to choose the one with the subaru part number in parenthesis to be OEM.
Thanks,
1995 Subaru Svx L / AWD
Old 07-12-2011, 10:46 AM
XT6Wagon XT6Wagon is offline
Re: Best fuel pump without modification?
Walburo makes good pumps and should have one that doesn't require modification.
On the fuel pressure regulator... Why are you wanting to change it? Stock one is broken or going to forced induction?
Old 07-12-2011, 11:13 AM
msvx95's Avatar
It's just a phase
I thought walboro needed mod...I do not want to mod.
I think regulator is acting funny, but I'm not laughing.
Old 07-12-2011, 11:19 AM
why do you think the regulator is acting funny? typically it only affects the gas reading. If you want a complete assembly that works, I have one. You're going to pay out your a$$ for a new complete assembly which can probably only be purchased from Subaru.
Or find someone local with a spare. Not trying to push selling something since it's not something fun to package up. Just trying to let you know that its the better option.
Old 07-12-2011, 11:23 AM
msvx95's Avatar
It's just a phase
Nate, just trying to diagnose my bogging issue that I have a seperate post on. I've read people have problems with fuel pump or regulator which will make the car feel like it's dying while accelerator pushed. So I'm not sure which part I need. I'm hesitant to put any used fuel related parts on the car. Yes I know subaru parts new are expensive, hence my post now.
Regulator new is about 100....pump expensive that's why I listed options above.
Old 07-12-2011, 11:32 AM
Understandable. I'm not usually paying enough attention to realize people have other posts/threads on a similar subject which is why sometimes it is best to only post 1 thread, even if it crosses a couple different possibilities if it's trying to tackle a single issue. Keeps things more clear.
Have you tried changing the fuel filter, any codes? sorry if this is covered in your other thread. Bogging is usually caused by some type of inproper reading which is causing the ECU to either lean out the mixture too much, or more likely, richen it too much. If it's the sensor/ECU side of things causing the issue.
Edit: Just read through your other thread. Try checking your TPS and coolant temp sensor. Does this issue pop up within the first 15 min of starting the car or is it there all the time? If it's there all the time, it would point more toward the TPS, or otherwise you're going to need to double check your vacuum lines.
Old 07-12-2011, 11:37 AM
msvx95's Avatar
It's just a phase
I guess lets stick to my original post on this question of recommended pump, etc. My other post answers your questions. TPS was adjusted, new coolant temp sensor. This issue when the car is at temp and driving.
Old 07-12-2011, 12:11 PM
Jake@FAPFab's Avatar
Jake@FAPFab Jake@FAPFab is offline
11.24:1 E85
fprs nearly never go out, they are so simple it's tough to break em.
ect is where i'd start. TPS is another, but not as important as the ect
Old 07-12-2011, 12:37 PM
These details weren't in your other thread.
Since you were in there touching your brittle wires which are over 15 years old, you may want to poke around with a multimeter making sure the wiring is still in tact and no breaks. Which coolant temp sensor did you replace?
Use dielectric grease in all electrical connections between all sensors as well to be sure that isn't an issue and double check all connectors are snapped in when you do this.
All the reason to stick to 1 thread when trying to sort out an issue
Old 07-12-2011, 01:28 PM
msvx95's Avatar
It's just a phase
Nate, this post was a question of recommended pumps. You should reply with what you think the problem is on my "bogging" thread.
Old 07-12-2011, 02:50 PM
The only "mod" the Walbro requires is lengthened wires.
