Old 06-23-2011, 06:17 PM
moepower moepower is offline
whats the differents between head gaskets
I found 3 different thickness gaskets one is 98mm one is 100mm and 102.3mm I think its thickness but not sure
Old 06-23-2011, 06:30 PM
Re: whats the differents between head gaskets
Those are probably bore sizes. Thickness is usually on the order of 1-2mm.
Where did you find those anyway?
Old 06-23-2011, 06:36 PM
Cometic shows those sizes (Linky)
And yes, definitely bore sizes. Unless you've done something really nifty to your engine the 98 is what you want.
Old 06-23-2011, 10:38 PM
Cam Cam is offline
Our stock head gaskets thickness is somewhere around .066", IIRC. You would not want to change that unless compensating for something else, such as an aggressive milling of the decks on the head/block. It is important to control the distance between the cams and crank, for timings sake.
Also, our stock bore is 98mm, give or take. You are definitely looking at bore sizes, as has already been stated.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 06-23-2011, 10:50 PM
Quick question, is that the price for both sides or only one side head gasket? I was under the impression they were a lot more expensive?
Old 06-23-2011, 11:14 PM
I think they must be for both.
Old 06-24-2011, 06:33 AM
They are.
The Cometic price of $121.00 is for one gasket only. You need 2.
When I rebuilt the engine in my polo, the gaskets in 2009, they ere $165.00 each
Old 06-24-2011, 07:14 AM
It should say SET ... If not I would think each. Back in the day 1964 ... I bought a rebuild gasket set for my 283 Chevy for $150.00. I got 50 +gaskets.. YEA those were the day my friend .
Old 06-24-2011, 09:30 AM
Cam Cam is offline
The price has not really gone up on those. It's a chevy... The SVX is rare and parts are for the most part not being made anymore. I just helped a friend rebuild his 350 and it cost him $1300, including pistons, rods, crank, machine work, gaskets, heads, and a couple cans of paint.
Cam
'92 Ls-L Dark Teal
Old 06-24-2011, 05:12 PM
They are.
Thanks for the clarification John. I'll just be using the OEM HG I have laying around for the pearl then. If that were the price for the set, it would be very tempting to spring for those for the added peace of mind.
