Old 07-24-2008, 10:37 PM
Hondasucks's Avatar
Subaru Technician
Re: weight issues
The thing with the SVX, is it is not a crotch rocket, it is designed to be quick and comfortable, which it does quite well. I'd focus more on making the engine more powerful, and swapping to a manual trans, than I would on just trying to cut weight... If you want a rocketship, shoehorn the EG33 into an EA82 three door, or a 2 door Impreza...
1986 VW Jetta
Old 07-24-2008, 10:55 PM
Re: weight issues
"3580
3580 lb car
- 23 lb drivers seat swap
- 13 lb front bumper exchange
- 20 lb rear bumper reengineer
- 14 lb lighter wheels (16.5 ea)
- 33 lb spare tire, jack and tools
- 8 lb trunk carpet + cardboard
- 39 lb exhaust system
+220 lb driver
+ 35 lb gas
3685 lb car
The stock headers weigh 18 lbs, the pipe from the headers to the muffler weighs 50 lbs, the muffler weighs 35 lbs, 103 lbs total. My system, from the home made headers, cherry bomb, 3” tubing + afterburner + polished tip weigh 64lbs. 39 lbs savings
So far 150 lb savings.
Note; 4 lb savings on underdrive pulley offset by added weight of adjustable FPR
I cut out the bracing from under the hood, 11 lbs.(the hood was a spare) Not recommended for the street.
Took off the iron bracket for the ac belt adjuster, 3 lbs.
Note, if the complete front bumper support was removed, it would be a 26 lb loss."
This document is probably four years old.
Even with the big brakes, supercharger ect. it is now down to 3300#s
with a 1/4 tank!
Just as a plug,
A fiberglass hood will save you 28.5#s.
Since this document I have re installed my power seat, and remover the AC sot hat I could run a proper belt on the SC.
The glove box door can be modified to save 2 GAS SAVING #s!
PS, that was 12 exhaust systems ago!
Old 07-25-2008, 12:09 PM
tubbstcg tubbstcg is offline
Re: weight issues
All of these ideas are considerable....The thing about making more power isthat it is about 5x more exspensive at this point than losing the weight 10k for a supercharger that is about 250 whp not to mention all of the other expensive goodies. making the car lighter seems more viable to me right now atleast untill we can drop the price of some of the svx performance goodies
Old 07-25-2008, 05:04 PM
sicksubie's Avatar
Re: weight issues
Originally Posted by vlmaclean View Post
eastcoastswappers.com and enhancedstreetperformance.com will do a complete STi swap. Other than that, acid dip the whole frame and rebuild a base model car with as little as possible.
Where are you located as both of those places you mentioned make me think that you are in the northeast. ESP is where I go to dyno and I really doubt that they would do the swap and a STi swap is not going to shave a lot of wait as that sticks the 6spd on which is just as heavy as the 4EAT. Add all the IC piping and FMIC and turbo.... The only thing that would get a lot lighter would be your wallet.....
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 07-25-2008, 06:02 PM
Subafreak's Avatar
Superbeast
Re: weight issues
Originally Posted by It's Just Eric View Post
Jesse's car was pretty light ad absolutely streetable...Racing seats up front, nothing in the back, steering wheel from a legacy (no airbags) battery relocated to the trunk (Weight distibution) power antenna and rear wiper/washer removed,no ac, and some other stuff removed....
Actually, my car tipped the scale at 3,200lbs with i'm guessing about 1/2 tank of gas. Things you can do without.Remove rear seats.replace front seat with lightweight bucketsreplace motor mice belts with 5 point harnesseslighten front bumper supportget fiberglass hoodremove rear wiper and washer partsremove front washer partsremove abs componentsremove cruise control componentscustom exaustremove air bags and componentsremove spare and jack.Thats about all i can remember taking out.I would add manual conversion but the 6 speed doesn't weigh much less than the auto.The moving of the battery behind the seat doesn't do much for weight reduction but more for balance, the same reason i didn't chop up the rear bumper support.I also kept the ac becouse the SVX doesn't really have the best ventilation with the half windows and all.It also helps to start with a base model, no moon roof, no wing, no power seats, and no ABS if it's a FWD model.These are plans if you still want a streetable and comfortable, semi full interiored, and faster SVX
Old 07-25-2008, 06:04 PM
Subafreak's Avatar
Superbeast
Re: weight issues
why oh why does the forum bunch all sentences into one big paragraph?
Old 07-26-2008, 08:11 AM
Myxalplyx's Avatar
XT6 is SVX's Daddy
Re: weight issues
1) Get a lightweight pulley, undersized even if you want,
2) Get lighter wheels than stock,
Kevin Thomas
***R.I.P***
