Exhaust back pressure
Has any one mesured the exhaust back pressure before and after they changed it. I recently read a artical were they tested it before and after to see how good a job they did. I will try to find it again.
Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
In the past there has been some absolutely stupid stuff posted in regard to tuned length by one in particular, together with lots of carry on about cat back stuff. All should note where the important tuned length starts and finishes, i.e., at the first point of expansion. The after market thieves, knowing their market is restricted to the exhaust system only convertor onwards, whistle some outlandish tunes. BY the way, a couple of times in different threads I have suggested that a few words from you, regarding your off road experiences, would be well received. Did you miss my posts? Thanks again, Trevor.
I will get the photos etc together for you over the next week.
Thank you for sharing. That is a must read for anyone contemplating exhaust modifications.
Gene
Gene and Ben 1992 SVX LS AWD 110K - Liquid Silver 1994 SVX LSi AWD 128K - White Pearl (daily driver) 1994 SVX LSi AWD 95K - Emerald Pearl (sold) 1992 SVX LS-L AWD 115K - Dark Teal 4.44 swap (sold) |
Autospeed has some nice articles. They influenced me into making a ram-air setup with one of my XT6s with the stock box (Negative Boost Article). I like their articles but some people do not.
Would be interesting to see what the stock SVX exhaust back pressure is measured at.
Kevin Thomas 1997 2.2ltr Subaru Impreza Outback Sport Wagon (AWD/Auto) 13.03@100mph 1989 2.7ltr Subaru XT6 (AWD/Auto) 15.912@85.93mph 1996 3.3ltr SVX (AWD/Auto) 15.070@91.38mph ***R.I.P*** 2010 RAV4 AWD Sport (13.717 @ 99.19mph ) 2015 Honda Fit LX CVT (15.2 @ 90mph) Last edited by Myxalplyx; 10-24-2007 at 08:20 PM. |
From this link from that article. http://www.autospeed.com/cms/A_107827/article.html
I have an old O2 sensor that we will drill and hook up a hose to get a reading from on the weekend. WE have two SVX's wifes with 140,000 kilometers on and mine with 420,000 both have the standard orginal exhaust. Mine has bent and squashed pipes do I am interested to see the difference in the readings. Should be fun. Will let you know how I go.
Good luck! Make sure the wife is a co-pilot (or someone) so you can get an accurate reading. Do not want to read about an accident due to reading the gauge while driving.
Kevin Thomas 1997 2.2ltr Subaru Impreza Outback Sport Wagon (AWD/Auto) 13.03@100mph 1989 2.7ltr Subaru XT6 (AWD/Auto) 15.912@85.93mph 1996 3.3ltr SVX (AWD/Auto) 15.070@91.38mph ***R.I.P*** 2010 RAV4 AWD Sport (13.717 @ 99.19mph ) 2015 Honda Fit LX CVT (15.2 @ 90mph) |
Took out O2 sensor and measured the back pressure on my car 420,000, would have thought the exhaust would have been all blocked up but it really didn't give any reading till 4,000rpm and that was about 4# at around 6,000 it was 7-8# was a bit hard to read as the engine had to be under load and at that reves you had to change gear before it red lined. I have a few minor leaks in the exhaust but with all the bashing from rocks and age you would expect for it to be higher.
Tony
Also since I wrote the last post I have removed the hose and fitting I tend to agree withyou because the hose on the end of the fitting was breaking up from the heat so not sure if it was leaking as well. I may test the other car this afternoon if I get a chance.
What pressure do you think we should target for? It would be good to get some of the better built systems that guys have put on tested.
If you must shoot for a target, shoot for 0 pressure. However, even a free flowing exhaustwith a muffler have at least 1-2psi of back pressure, according to the article. I would shoot for 1-3psi to be reasonable.
My problem is that the standard SVX exhaust is brillant I have bent & squashed pipes, mounts that are now 2in back from were they were suppose to be and its still origanal and still works. In 400,000 k the only thing I have replace is the centre resonator that I removed. I am just not sure that I can build one that will last the punshment like the orignal. We don't have to test car admisions at rego as you guys do so I figure I might smash out the centre cats to help the flow.
Tony
The OEM SVX exhaust system demonstrates brilliant scientific design and achieves ultimate performance, given the constraints involved relative to noise/silence and emission issues. An important aspect is the location of a very large terminating silencer at the rearmost position possible. In this regard the sideways positioning of this final opportunity for gas expansion is noteworthy. Eliminating the centre “cats” will improve flow as you suggest and should not affect the original design strategy. Your ideas make sense, Trevor. P.S. Those intent on more or different noise, or a minor improvement in efficiency, should simply modify and reduce restriction in the internals of the large final element in the system. There will be no after market "cat back system" which can better or equal the original. A home grown twin pipe system remains in another ball park.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! Last edited by Trevor; 10-27-2007 at 06:39 PM. |
