Old 07-24-2005, 03:34 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Battery shut off switch
Alright electrical geni out there. We're looking for a battery cut of switch and have 2 questions
1. What amp rating does it need for continuous amps?
2. Do we need an alternator kill switch as well or will it die when battery is cut?
Old 07-24-2005, 03:40 PM
thundering02's Avatar
Giong back to the beaters...
If you wire it so that you cut the battery off completely then yes alternator won't do you aything if its not running. You can find kits from places like summit or raceshop etc. but other wise I'd say get an amp kit 4guage or better if your going to do it custom.
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 07-24-2005, 04:02 PM
benebob's Avatar
Well it has to be SFI legal so it will need to be manufactured by someone. Cutting it off completely (as in all the positive gone will shut it down???) Battery of course is in the trunk so running wires forward to shut off the alt wouldn't be fun, especially if I don't have to add the extra 5 ounces.
Old 07-24-2005, 04:47 PM
UberRoo's Avatar
UberRoo UberRoo is offline
SVX Appeal
If the engine is running when you disconnect the battery, the alternator will continue to run and produce voltage. I've heard it said that this can damage the car's electrical system, but I've never heard of it happening. Enough current is drawn during normal operation of the engine that some degree of voltage modulation will occur and the alternator is not likely to fry anything. I can't speak from experience with an SVX, but I've done it and seen it done with many other cars. The voltage did not rise in any example I've witnessed.
Many alternators have a wire which runs directly to the positive battery terminal. There is usually another wire that goes directly to the starter motor, and one that goes to the fuse box for everything else. I'm not sure what the purpose of the disconnect is, but if you leave the alternator connected to the battery, and put the disconnect in the wire that goes to the fuse box, the alternator will be unable to power the car's electrical system when the disconnect is opened. There's really no need to provide a disconnect for the starter motor wire, but you can attach it on either side of the disconnect.
Presumably this is for racing. Do the rules specify what needs to be disconnected when the switch is thrown? Obviously, if the alternator is left in the circuit, the rules either recognize that the alternator is unable to produce anywhere near the amount of current that a battery is capable of and that it will fail if there is a sufficiently large short, or the rules are stupid and don't appreciate that the alternator will continue to function. It really depends on the purpose of the rules. Do you even care, or are you just trying to satisfy the regulations?
UberLocker
Old 07-24-2005, 04:53 PM
benebob's Avatar
Car needs to die when it is pushed. Like a kill switch on a motorcycle
Old 07-24-2005, 08:44 PM
UberRoo's Avatar
SVX Appeal
In that case, I'd just find the ignition wire and install a switch. Some of the nicer car security systems do this.
Still, if you leave the alternator connected, the car will probably continue to run. If disconnecting the ignition wire does not satisfy the rules, then the disconnect should go between the fuse box and the battery. On my SVX there's a lightly colored wire about a foot long that goes between the two. I don't know where the switch is supposed to be mounted, but I've seen people attach a piece of string to fuses or relays so they can just yank on it to shut off a particular device, usually the engine. It's cheesy, but it works.
UberLocker
Old 07-25-2005, 03:15 AM
Chris's Avatar
Chris Chris is offline
Founder / Administrator
Send a message via ICQ to Chris
I wire race cars and I am doing this project myself to my SVX. You need a master disconnect switch with a seconday circuit (normally called "with alternator disconnect/protect). There will be a pair of heavy duty terminals for going inline with the (+) side of the battery. There will also be a secondary switched circuit on it as well. Some people wire this inline with their voltage regulator for their alternator thusly killing it at the same time. For our car (SVX) it would be easier to connect the ignitor circuit to this second side of the switch, thusly killing the ignition when the master switch is flipped. I hope this helps.
-- Chris
Founder/Administrator SVX World Network
ECU Tune (stage 1), PWR (prototype aluminum radiator)
Amateur Radio - General Class - K7SVX
#1 92 Teal LSl 246k (Dedicated SVX Race Car, now with 4.44 speed)
#2 92 Teal LSl 125k (Retired, car rescued from a field of weeds)
2007 Impreza 2.5i Special Edition, Obsidian Black Pearl (Daily driver)
2001 Dodge Ram 2500 quad cab, Cummins turbo diesel 4x4 (race car & RV hauler)
1985 Honda VF500 Interceptor (fair weather fun commuter)
Going on 11 years of NHRA bracket racing
NHRA Div 6 Car/Driver # T654 (site being rebuilt, new name is www.teamsvxracing.com)
2000 1st Place Club Challenge Series
2002 3rd Place Season Track Champion, Import Racing (Firebird Raceway)
2003 4th Place Season Track Champion, Import Racing (Firebird Raceway)
2003 1st Place NW Regional Import Shootout (July 5th)
2004 1st Place Club Challenge #1 (Firebird Raceway)
2004 1st Place NHRA "King of the Track" race
2004 NHRA Gold Cup 2nd place season win
2004 Import/Sport Compact 3rd place season win
2004 Division 6 Summit/ET NHRA Race of Champions finalist competitor (Mission, BC)
2007 1st Place Import Survival #3
2007 1st Place Track Champion Import Summer Jam (Wild Street Class)
2007 1st Place Import Survival #5
2008 Club season 1st place win, Club Champion
2008 2nd Place Season Import Final.
2008 Division 6 Summit/ET NHRA Import Finals (Woodburn, Or)
2009 2nd Place Import Summer Jam (Wild Street Class)
2010 1st Place Club race #2 - 1st place Sport Compact race #1 & #2
Old 07-25-2005, 04:22 AM
gsodonis's Avatar
gsodonis gsodonis is offline
Hella Battery Disconnect Switch
Here's one made by Hella. It was standard fare in all IMSA prototypes in the 80's and 90's when I was building them. Summit Racing has them for around $18 (plus $8 for shipping). I have a brand new one I'll sell you cheap if you're interested. PM me.
Summit Racing Battery DisconnectsThe Hella battery disconnect is in the middle at the bottom of this link.
Don't let its price fool you; It's a well made switch. Once you remove the key, the switch acts like an anti-theft because without it (the key), you can't re-energize the car's electrical system.
Old 07-25-2005, 02:11 PM
UberRoo's Avatar
SVX Appeal
A buddy of mine has that switch. He was pretty ticked off when he found out that he couldn't remove the key when it was in the ON position. He installed it and then...what the? Dammit! (It sticks out the key cylinder hole for the rear hatch.) I was thinking about coming up behind him at a stoplight and swiping the key.
UberLocker
