Old 05-01-2005, 08:08 PM
RED FERRARI
Performance mods?
Hi, My SVX currently has a Green high flow Air Filter and the ECU Tune Stage 1 kit on it . I plan to buy in the future a stebro exhaust, Small Car Shift Kit, and a light weight crank Pulley. Are there ANY other mods you can do to the SVX othe than real expensive mods such as a 5speed swap- my transmission is perfect right now, Gears, Nos, and turbo or supercharger that will make more horsepower? Also is it worth it to take out my intake resonator considering the fact that I have a High flow filter already installed? Will it help make a few more hp on top of my intake if removed? Thanks for your advice
Old 05-01-2005, 09:16 PM
n00b on demand's Avatar
Your trans is perfect you say...to keep it that way I say get a transmission cooler in there. You could also get koni struts and some drop springs. As well as some drilled/slotted rotors from raceconcepts.
Old 05-01-2005, 09:55 PM
One other major thing would be stainless steel brake hoses. They make a major difference.
Old 05-01-2005, 11:43 PM
svxsubaru1's Avatar
I would have to aggre, i havent driven a SVX with them, but other cars (subarus) that i have driven have benifited greatley and my SVX has some horrible pettle feel after a couple of hard stops and i doughts its my ATE blue racing fluid bowling, or my metal masters being overheated. Thats probley going to be my next upgrade, besides fixing my car that just got hit.
Old 05-02-2005, 12:40 AM
WGJ WGJ is offline
Performance Mods
I urge you to heed the advice to improve brakes and handeling of the car, first. While I greatly appreciate the desire for more speed/power...unless you're going to race I'd focus initially on using what you've got. I'm biased. I live in a pretty heavily trafficked urban environment and rarely get to haul ass. But I really enjoy taking freeway on-ramps with a 35 mph sign at 70+. Nearly everyone on our freeways drives at least 70, often 80-85, IN ANY LANE, and rarely bother to signal. The better brakes and tires have already allowed me to avoid several idiots. Once tires, brakes and suspension are done, autocross the car or take a high performance driving course. Learning the handeling dynamics of your SVX in extreme situations pays off on the road. You'll know when you're ready for more power, you'll have a great time AND become a much better SVX driver.
As cool a GT the SVX is, it's not really suited to racing in stock form. Too heavy for starters. If you really want to really race, get a kart or a used Miata and go racing. Does that make sense?
Having the driving skills to haul ass without the risk of killing someone, going to jail or summary execution is some of the most fun you can have, period.
WGJ
Old 05-02-2005, 09:33 AM
AFBeefcake's Avatar
Subaru Swapper
You can get a MSD Stacker Ignition system. I got one and it seemed to add a little power, but I have not had my car dyno'd
Also not really a performance mode but upgrade the ground and power wires from the alt to the battery and frame.
poly front and rear sway bar bushings.
I cut my intake resonator off at the first bent where it was all ready cut haft way. That way the air box is still sealed to the fender.
2005 Legacy GT
My WRX's Cardomain Page
Old 05-06-2005, 10:27 AM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Wink
by pass the coolant flow on your throttle bodies. makes a healthy improvement in throttle response. search for a thread on it in here. also do the alt. upgrade. it helps the electrical system alot.the exhaust is a good thing to play with too.
Old 05-06-2005, 11:06 AM
Jnthn_Sctt Jnthn_Sctt is offline
This is a new one to me. What does bypassing the coolant do?
Thanks,
Jonathan
Good people sleep peacefully in their beds at night, only because rough men stand ready to do violence on their behalf.
Old 05-06-2005, 01:41 PM
The coolant heats up the throttlebody and prevents freezing.
Without this the intake air is cooler. The phenolic spacers help in a similar fashion (cooler air to the engine)
Old 05-06-2005, 02:23 PM
Budfreak's Avatar
Banned
Wink
Thanks,
Jonathan
exactly as earthworm said, it allows the intake to stay cooler and therefore make more power. just make sure you reconnect it in fall when the temps start falling below 40 or so degrees.don't want your throttle to freeze open.
