Old 01-15-2005, 11:28 PM
BATMAN
Shifting muffler between the axles for reduced rear weight?
As u can see here, the muffler(s) in stock format resides behind the rear axle.
I was just thinking if anyone has "gotten away" with just installing a muffler where the stock "resonator" resides and running straight pipe towards the tips.
Noise too loud?
This should reduce weight, and in theory improve handling.
I'm not sure about the AWD/FWD and weight distribution dynamics with the SVX, but with the RX7 guys we notice a shift in the weight from exhaust work.
Old 01-15-2005, 11:48 PM
SubaSteevo's Avatar
No longer blue member
I highly doubt the weight of one muffler is going to have any noticeable effect....
besides, on an RX7, wouldn't removing weight from the rear=less traction=bad?
-Steve
01' MSM Lexus IS300
Old 01-16-2005, 11:34 AM
Why would you want less weight in the rear?
The SVX is front heavy.....if anything move your battery to the trunk to help even the weight out....
The front needs lightening, not the back...
Just my humble opinion....
Old 01-16-2005, 11:50 AM
SubaSteevo's Avatar
But that's what the bodies are for
-Steve
01' MSM Lexus IS300
Old 01-16-2005, 02:29 PM
mbtoloczko's Avatar
sans SVX
Besides what Huck says, I'm not sure there's much room for a muffler on the forward side of the rear halfshafts. Maybe a 4 inch round body could fit there cleanly, but not much else.
Mychailo
Visit my locker
