Radiator fan/relay question
Ok... Have some serious electrical gremlins in my svx. I posted another thread about it, actually taking a trip shortly to mt, a friend's dad there owns an auto electric business, so i'm gonna have them figure it out lol.
My question is: Can I jump the fan relay so that they're always running with the key? I basically don't have a problem as long as the car's moving, but if i have to sit in traffic it gets hot... Somewhere along the line I lost the fuse/relay cover under the hood. So i actually have no clue which is the fan relay. Can someone post a pic? Which terminals would I jump to keep the fans going with the key? Thanks guys |
Re: Radiator fan/relay question
Yes. You can run it to your ignition. Just splice in behind the connectors, and run the line to a spot under the interior fuse panel. Probe around with a multimeter to find the a spot (white plastic) that is the positive source. It should only be hot when the key is forward. You can ground the wires anywhere, but I am not sure if it is necessary or not. They may already be grounded.
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
Fan fuses would be top left 2 fuses as you face the driver. Right next to a set of 4 relays. Top is main fan and under that is A/C sub-fan. I'm currently replacing my sub-fan as it's blowing it's fuse due to high resistance in the fan itself, drawing about twice the current specified. If you wire up direct through the ignition you risk damaging other components and wiring. Just my $.02.
Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket |
