#46
What we need is a way to accurately measure more air flow utilizing the existing equipment or else swap for equipment that will. We already know the stock MAF will not measure accurately over 5600RPM regardless of what you do to the wiring/ECU.
#47
I didn't mean to inspire a hijacking of the thread. I was just suggesting that the maf voltage output be the next analog data he log along with afr.
#48
#49
I log data for both wide band and MAF voltage on my CAMP system. But this does not help much due to the fact that it is on a turbo car.
www.svxtasy.com |
