Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Other Mods
Old 05-07-2005, 10:45 AM
Rotorflyr's Avatar
Rotorflyr Rotorflyr is offline
9005 conversion
I plan on doing the 9005 conversion in a week or so, and was wondering if anyone had just purchase the 9005 socket/wire kit you can get at WallyWorld (about $8 for both sides) instead of cutting/grinding on the bulb housing* itself??? You know cut the 9006 socket off and splice and wrap/heatshrink the new wire/socket into place instead of modifing the bulb, saving you from having to mod the bulb everytime you have to change em'
Also anyone out there try or hear anything about the GE Nighthawk bulbs?
*edit-for the conceptualy challanged
1992 Liquid Silver LS-L (Sold-5/16/13)
1997 Spruce Pearl Outback (Sold)
2006 B9 Tribeca
Old 05-07-2005, 03:32 PM
thundering02's Avatar
thundering02 thundering02 is offline
Giong back to the beaters...
I thought you just had to grind a couple of tabs off....somebody with a search button or a link saved fix this thread
86 GMC Jimmy Blue and Silver- R.I.P.
87 Integra RS ~228k miles R.I.P.
92 SVX LS-L Perly ~186k R.I.P.
89 240sx se red ~165k miles Gone and unknown
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
85 BMW 325e ~ Gone and unknown
85 Ford Mustang getting engine swap now!
05 Colorado ~108k Daily Driver
Old 05-07-2005, 04:10 PM
Rotorflyr's Avatar
Thats what I meant, you cut the bulb housing to fit the 9006 socket onto a 9005 bulb, where as splicing in a 9005 socket (bout' the same amount of work) you don't have to do it every time you replace bulbs (which while hopefully not often, will happen) So there's really nothing to fix on this thread.
2006 B9 Tribeca
Old 05-07-2005, 04:59 PM
It is the light housing that is another problem, so you would have to grind that off even if you replaced the socket.
Old 05-07-2005, 05:49 PM
n00b on demand's Avatar
Modding the bulb to fit takes like 5 seconds anyway. Its not hard at all with an exacto knife!
Old 05-07-2005, 05:53 PM
Rotorflyr's Avatar
Didn't think it was hard or time consuming, just looking to make the long term process eaiser (and a touch quicker), would it be possible to cut/grind the light housing without any negitive effects??
2006 B9 Tribeca
Old 05-07-2005, 05:56 PM
I dont think there would be any negative effects of modding the housing. I think it would be a PITA to do that though. But i dont think there should be any negative effects of doing it
Old 05-08-2005, 04:20 AM
94svxred 94svxred is offline
I JUST BOUGHT 80 WATT 9006 BULBS FROM STREETBEAT.COM . THEY LOOK GREAT WIYHOUT THE WORK
Old 05-08-2005, 04:05 PM
Subafreak's Avatar
Subafreak Subafreak is offline
Superbeast
The answer is yes, and it's not a bad idea at all. The only other thing you have to do to the bulb is cut a little bit off of one of the tabs to make it go in the housing. No big deal at all.
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs.
91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch.
78 BRAT (New toy) (Soon to be EJ22T powered)
90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car)
To many cars to spend time on teh web!
